Replacing Fuse Block
Guys,
As I have been having electrical issues, I plan on replacing my fuse box this weekend. Unfortunately, I believe the current wiring was jacked by the PO and I do not time to get a bentley manual. Cold someone please post pictures for a 78 911 or point me in the direction of good schematics? Thanks A picture of my current box is shown below. As you can see it needs shot and sent to the glue factory.
1978 911 3.0 fully rebuilt and for sale |
Nobody??? You guys love posting pictures
Does somebody have a schematic for the fuse box. I have the old one off and I would like to wire the box back to the stock set-up
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
gjs
Let us know how big a job this turns out to be. What are you replacing it with? I have had several fuses which look good, but were the problem and should do the same project. Thank, Glenn
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff 2015 Cayman S 1948 Willy's Overland Jeepster 2013 Chev Sub 2004 Nisson Xterra |
Thanks for the info guys, I have finished replacing the block. The PO used a a 12 fuse block and totally rewired everything. After replacing witha stock one everything seems to workk correctly --- except my turn signals arn't working.
It seems the two fuses for the turn signals do not have power. I used a test light on both and neither had power (with engine running. Any ideas??? ![]()
Fuse Block
Some of the fuse positions have a brass jumper built into the back side of the fuse block. Did you make certain that you have the correct fuse block? On my SC, there are a couple of fuses that have a power jumper wire running from the "top" side of a hot fuse to the "top" side of other fuse postions. If you know which fuses work the turn signals, you probably could just run a power jumper to those locations. On the SC fuse box. there is a red power wire running to the "top" of fuse #11 that (according to the factory wiring schematic) is from the "electronic ignition unit". Also, there is a red jumper wire running from there to the "top" of fuse #16. According to my schematic, fuse #11 is the one for the back up lamp switch and for the turn signal relay. Fuse postions #9 and 10 are associated with the hazard flasher. The fuse numbers are counting from the front of the car towards the back. Hope this will help you some.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
