Putting 3.0 in 1975 911S
I know that several Pelicans have put SC motors in mid-year 911S. What mods and parts are required to connect a '79 SC motor in a '75S? I will include a photo in a later post. Thanks!
Tom 1975 911S 1982 911SC w/ 3.2 SS
Thomas Warren 82 911SC w/ 3.2SS 75 911S (disassembled) 1966 Lotus Elan FHC |
Subscribed
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Home of the Whopper
Just off the top of my head:
3.0 Engine wiring harness Tach CD box Oil cooler ?CIS? Box under pass seat
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S Last edited by BK911; 09-17-2009 at 02:56 PM.. |
When I put the 77' 930/02 in the 74' targa I had to fuss the following:
- While the connector for the electrics from the engine to the car was the same, the pin outs was different. In my case the CID was 3-pin in both cases, but the FI was different. This was not hard to get right. - The CIS fuel feed lines were different fittings. - I put the aluminum differential side cover on my Magnisium 915 to help with the bigger load. - I put the SSI Hx from the 2.7 onto the 3.0 so I had to take some of the air baffling from the 2.7 to the 3.0 That is all I can think of, the rest is a direct fit.
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
Thanks for the input!
I just did this in a 76- see these threads-
Tach Wiring Drilling Hole for ECU '81 CIS ECU wiring question 76 widebody project 2.7L to 3.0L Engine Conversion / Swap It isn't hard to do, oncew you know what to look for. If I can find time I'll write up a guide on what I had to modify and how. In the meantime, ask lots of questions.
Rob 76 widebody project 86 Carrera Coupe 01 BMW X5 98 Jaguar XJ8 Last edited by avt007; 09-19-2009 at 08:56 AM.. |
