Trailing Arm Monoball Install
Is there any reason I cant disconnect the CV, brake lines, shock, brake cable, spring plate and remove the trailing arm to install the Monoball without getting into disassembly of the hub/removing rotor/etc?
I dont have the special porsche tool referenced in the bentley. what are others doing? Thanks in Advance. Brad |
It's possible to install your monoballs without removing any of that. I did it with everything installed but if I remember I took the spring plates off.
I replaced mine while the engine/trans was out. But otherwise everything else was connected. Not sure I oculd have done it easliy in the car if the trans was still in place.
Thanks all. I ignored the bentley on this one... Got them installed.. now off to the T-Bars...
