brads911sc's Avatar
Trailing Arm Monoball Install
Is there any reason I cant disconnect the CV, brake lines, shock, brake cable, spring plate and remove the trailing arm to install the Monoball without getting into disassembly of the hub/removing rotor/etc?
I dont have the special porsche tool referenced in the bentley. what are others doing?
Thanks in Advance.
Brad
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 09-20-2009, 07:40 AM
Alii&Maui
Jesset100's Avatar
It's possible to install your monoballs without removing any of that. I did it with everything installed but if I remember I took the spring plates off.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 09-20-2009, 08:19 AM
175K911's Avatar
I replaced mine while the engine/trans was out. But otherwise everything else was connected. Not sure I oculd have done it easliy in the car if the trans was still in place.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 09-21-2009, 07:08 AM
brads911sc's Avatar
Thanks all. I ignored the bentley on this one... Got them installed.. now off to the T-Bars...
Old 09-21-2009, 09:17 AM
