Headliner Installation Question
I am installing a new headliner in my 84 911 that I have apart for painting. The existing burgundy headliner is not in bad shape compared to some but since I have the glass out I want to update it.
I have read several posts on the subject and have not found much info on the metal rods used in the C pillar base area. This is a sunroof car. The original headliner has a pouch and short metal rod ( about 8" ) at the base of each C piller to fix that point tight. The replacement liner does not have these pouches sewn in. Has anyone tried to sew in the pouches to make a better connection point along that area or is it not necessary ? I was thinking or taking the old liner out and using it as a template to reproduce the pouches. The only trouble I see with this approach is that it may be difficult to keep things tight, you would almost have to start there and mover forward , which is probably very difficult, I believe you have to work for the center to the corners. How have others dealt with this issue ? Thanks Ross |
headliner
Completed the installation of the headliner on my 71E recently and ran into the same issue. No pocket, so I wrapped the rods with the headliner and glued it in place, leaving it just short enough to get some stretch when fastening down. If i remember correctly, I did this dead last.
Regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
THanks
That is a good idea, I never considered glue as I didn't think it would have the hold required.
Did you use the same glue that you used for the edge gluing ? What product is it ? Thanks |
I used Permetex Super Weatherstrip Adhesive, as well as the 3M brand (the yellow, elephant snot) with good results. Due to the extra length of the headliner, in that area, I was able to roll the headlined around the rod several times.
Regards, Al
Recreational User
I also made my pockets using super weatherstrip adhesive. This was one of the last steps in my headliner installation.
First I stretched the C pillar section down to tension it, and then I marked the position on the headliner of each of the two prongs that hold the bar down. Then I marked a line between them, which gave me the exact location of where the fold should be. I applied the glue, placed the metal bar in position, and folded the headliner material over the metal bar, right where the fold mark was. It worked perfectly. |
Thanks guys , I will follow your advice and use this method.
Ross |
AutoBahned
can you post a pic of the burgundy headliner?
I've only seen black, white & red felt... |
Sure ,
I will post a pic , it will be tomorrow I left my camera at work. I bought the burgundy from GAHH . It is pricey at about $210 but an excellent match to the original. Ross |
I found the camera, here is the new liner phots as requested.
AutoBahned
nice!
