cantdrv55's Avatar
If I upgrade my SC's suspension will it...
If I upgrade the suspension will it become less raw and tossable? I have the parts already; Carrera sways, thicker torsion bars and that bar across the shock towers. Will I become disappointed or pleased? I want my SC to be flatter on the corners but I don't want to give up the tossable quality. What's been your experience?
Old 09-26-2009, 10:56 PM
Moses's Avatar
It will be MORE of all the things you like. More tossable, more responsive. more visceral.
Old 09-26-2009, 10:58 PM
Once a friend of Cliff
juanbenae's Avatar
silly maybe-so....... someone's always watching.....
Old 09-26-2009, 11:21 PM
450knotOffice's Avatar
The answer is a resounding YES! I upgraded the suspension in my Cab about 4 1/2 years ago and found that it is eminently more "raw" and "tossable". The suspension will be stiffer, which will mean it will take a set more quickly during the turn-in to a corner, and therefore will react more quickly than you are used to now. It will feel less ponderous during transitions and therefore will feel as if it is lighter.
Over the years I have driven quite a few stock 911's and can say that I notice quite a difference between those cars and mine.
Old 09-26-2009, 11:28 PM
Dumb question, do you have the shocks/strut inserts to match the rest of the parts?
I had my shocks & struts replaced and that made a huge difference... My mechanic recommended I hold off on the T-bars and swaybars until I had tried the new shocks first, and so far I'm happy with the decision. Car could be a bit more stiff, but the handling, especially on less-ideal roads, is much improved.
So, the shocks will play into your "tossability" results.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 09-27-2009, 07:03 AM
Platinum Member
dad911's Avatar
While your in there..... Bushings & Shocks/Struts.
Old 09-27-2009, 07:14 AM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
slippery slope warning!
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 09-27-2009, 07:20 AM
Its well documented that the Porsche Upgrade is a unstable system. Even considering an upgrade is enough of a disturbance that your wallet will be empty before you know it.
I'm desperately resisting the urge to upgrade. With the rainy season here and Winter after that I can't bring myself to spend the money only to garage the car until spring... Not that I'll earn much interest, but hey, its something.
Old 09-27-2009, 07:30 AM
175K911's Avatar
Not sure what you mean by "thicker torsion bars", but if you've got the later Carrera bars, the front is the same between the SC and all 84-89 Carreras. The 84-86 Carrera got a 25mm rear tb vs the SC 24.1mm. So if that's what you have, then you'll have a car that feels like a Carrera.
Frankly, I occasionally drive my 911 on the street occasionally with 23/33 TBs, big sways, Elephant bushings and monoballs, custom valved Bilsteins and R-comp tires. Sure it's "firm" but it's still a blast to drive. Though I wouldn't want to take a family trip this way.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 09-27-2009, 07:33 AM
Reduce the cars weight as much as you can and you will be rewarded in the toss category.
82SC Track Car
Old 09-27-2009, 08:08 AM
GaryR's Avatar
Send a message via ICQ to GaryR
One word - Polybronze
Gary R.
Old 09-27-2009, 08:19 AM
Information Junky
island911's Avatar
Just weld all the suspension for the best Upgrade EvAr!!!
...wait, where did that green text button go?
Old 09-27-2009, 08:55 AM
grateful user
don gilbert's Avatar
I just wanted to do the turbo tie rods and it turned into this. Poly bronze and biltein hd's, and all the other goodies, its like a whole nuther car.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 09-27-2009, 09:35 AM
cantdrv55's Avatar
Well I started with sport shocks all around with the help of Vash. I've had those for about three years now. At about the same time, a couple of Bay Area Pelicans installed turbo tie rods for me. I've been collecting the other bits since then. I don't remember now how thick the tbars are but at the time I thought they'd be a good upgrade. Anyway, thanks for getting back to me guys. Can't wait to get these installed!
Old 09-27-2009, 09:57 AM
Information Junky
island911's Avatar
fwiw, Ruf, with the Yellowbird, simply put in bigger sway's, for better/flatter handling/feel. They left the OE T-bars as they, apparently, still wanted to have compliance to handle real-world pavement irregularities.
Old 09-27-2009, 11:27 AM
ToddM's Avatar
Vash!?!!??! Oh No!!!!!!
-Todd
Old 09-27-2009, 12:11 PM
Have a measured plan aka all components match up with the type of driving you do most.Also go to a track event and if possible drive or ride in cars stock and setup to your style.Cheers Chuck
Old 09-27-2009, 12:29 PM
