BBS rears on a SC body
Porsche 911 wheel size question: I've asked this question to 10 different people and usually get 10 different answers - i am hoping for a consensus. Can a SC body style (1988 911 Carrera) take 16x9 BBS rims on the rear ? fenders are rolled for my current 16x8 fuchs. Does tire size matter? thanks for sharing your experiences... Joel
Old 09-17-2009, 12:42 PM
KNS KNS is online now
It depends, what is the offset? Bolt spacing is correct? 16x9 Fuchs I believe are 15mm offset and fit just fine.
Kurt
Old 09-17-2009, 01:04 PM
DUK DUK is offline
DUK's Avatar
Yep...245/50/16 I'll have to look for the offset.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 09-17-2009, 02:09 PM
Almost Banned Once
sc_rufctr's Avatar
Originally Posted by DUK View Post
Yep...
They look cool. Super Old School. Love it!
I wonder how 17 inch rims with the same centres look on that car?
- Peter
Old 09-17-2009, 02:11 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Need the offset number since they're not all the same. A ET +15mm and ET -1mm will fit a SC no problem. There is a ET +36mm that has too much positive offset IMO and you may have rubbing inside the wheel well on the chassis tub. I run the ET+15 wheels on my '87 Carrera and use 14mm spacers behind them and 245/45 Kumho Victoracers. I have plenty of room both inside the fender well and at the fender lip. I have the camber near maximum negative and have NOT rolled the lips of the fenders.
Why are your rear fenders rolled for the 16x8 Fuchs? There's tons of room between the tire and the lips with 225 or 245 tires. I have run both 14mm spacers and 21mm spacers behind 16x8 Fuchs with no rolled lips.
Kevin L
'86 Carrera "Larry"
Old 09-17-2009, 02:12 PM
16x8 Fuchs fit an SC without rolling the fender.
Friend has 16x9 Fuchs on his 78 with no fender roll. The extra inch is on the 'inside' of the 9's.
Depends on the offset of your wheels.
Old 09-17-2009, 02:25 PM
These are 16x9 ET 11 with 245/45 tires, need a little neg camber to not rub.
Old 09-17-2009, 04:24 PM
thanks guys - a couple nice looking cars ! how do you like those cone mirrors, did body work take care of the mirror holes on the door - or fiberglass doors?
Old 09-17-2009, 05:29 PM
DUK DUK is offline
DUK's Avatar
I like the ruf mirrors, but I also have a large inside one. And we filled the holes in the doors.
2000 & 2007 Dobies
Old 09-17-2009, 05:40 PM
Monkey Butt Forespin
84_Carrera's Avatar
Running 16x9 BBS RS on the back with 245/45-16's. NO issues at all, no rubbing, non-rolled fenders. 16x8 fronts though, with 225's, and I have an occasional rub.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 09-18-2009, 09:07 AM
Mike911SC's Avatar
Porsche Crest
Fred - Whatis the offset on the BBS 9's you are running in the rear and are you running any spacers behind them? I am in the process of having a made to order set of BBS RS wheels made in 7" for the front with a 23mm offset and 8" for the rear with an 11mm offset. I am considering making a chnage in my order to up the rears to 9" but would like to know what offset you are running. Can you also post a picture of the BBS wheels on your car?
Why doesn't life have background music?
Mine does: '82 Targa 911SC
Old 09-28-2009, 08:13 AM
Less brakes, more gas!
euro911sc's Avatar
The 16x9 et 36 BBS RS wheels will fit with a 1" spacer. The lip on those is only about an 1". I'm building similar wheels to you except I have 8" up front. My 9's should be about a 10-10.5 offset and should run w/o spacers from what I have read/researched. They will have a 2.5" outer which should have a nice dish, but not ultra deep dish.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-28-2009, 09:04 AM
84_Carrera's Avatar
Mike -
I sold my car last week, but I believe at home I have the pics documenting the serial numbers etc on the centers & halves. I'll check.
Ed Hughes (efhughes3??) here was who I bought them off of, he may remember off the top of his head.
Oh, and no spacers on the wheels at all. I had 1" all around when I was running the 968-style wheels.
Fred Hurder Jr
For Tech Questions:
Old 09-28-2009, 12:11 PM
