-   -   Need part number? (http://forums.pelicanparts.com/porsche-911-technical-forum/501785-need-part-number.html)
crashr 09-27-2009 12:40 PM
Need part number?
I looked through the entire online pdf parts catalog but couldn't find the part number for the rubber grommet that seals the hole in the body where the DME wiring harness passes into the car from behind the drivers seat. Does anyone know what part number this is?
Thanks,
crashr 09-28-2009 11:20 AM
lucittm 09-28-2009 11:31 AM
It might be part of the wiring harness itself. I had a similar issue with the grommet that holds the rear brake ABS wiring to the lower chassis. The good news is that a wiring harness of almost any year/model will work.
Thanks,
Mark
crashr 09-29-2009 09:12 AM
That could be. Can anyone else confirm?
crashr 05-05-2011 05:07 PM
still can't find it in the PET. bump
crashr 05-09-2011 05:59 AM
ttt
crashr 05-09-2011 06:49 PM
DOes anyone have there engine out with wiring harness, or could someone confirm for me the diameter, inner/outer of the grommet used.. I guess I could try mcmaster-carr or someone and see if I can't something up that might do the job.
JJ 911SC 05-09-2011 07:17 PM
Dennis
Can do but not sure yet which one you talking about...
Here is a pic with the engine on the wall with the wire harness fitted. None of these wires go back directly to the cabin.
Let me know what you want me to do a close up/measured.
JJ
http://forums.pelicanparts.com/uploa...1304993827.jpg
crashr 05-09-2011 08:11 PM
Hi JJ,
THe part I am interested sits around your main wiring harness that goes to your DME. The cable passes through the firewall below the rear seats. It is at that point where there is a grommet to seal the hole and let the cable through. From what I am being told, some people feel it might be part of the DME cable harness (although my engine didn't come with it).
JJ 911SC 05-09-2011 08:31 PM
Dennis
Like I mentioned, none of the cables on the engine harness goes through the fire wall but the large connector (14 pins) hanging down by 17mm wrench (2nd from the left) in the photo in post 8, does connect to another harness.
Tomorrow after work, I'll take photos of the wire going though the fire wall.
Should be posted by 19:00.
Bonne nuit
JJ
steely 05-09-2011 08:32 PM
With the engine out, the harness is disconnected from the 14 pin connector above the firewall, so looking at the engine (half of the) harness won't help. You want the half that remains in the car.
I agree that the PET doesn't show enough detail.
You want someone with the engine out to look on their firewall, correct?
(someone posted while I typed - there ya go)
JJ 911SC 05-09-2011 08:37 PM
Dan
Don't you hate that when it happened :)
I'm usually the late one... Typing with 2 fingers does not help either :D
Cheers
JJ
JJ 911SC 05-10-2011 02:51 PM
Dennis
Here are the photos.
All taken from the engine bay looking forward.
On the first one, the biggest opening is where the shifter engage the transmission.
On the second one, its probably the plug you are referring to. Keep in mind that my car is conversion to a 3.2 and it lookalike that the plug was not fitted from the inside. If you can picture it, this plug would be perfect if it was in the cabin.
The last one is another plug for another wire going in.
http://forums.pelicanparts.com/uploa...1305063986.jpg
http://forums.pelicanparts.com/uploa...1305064012.jpg
http://forums.pelicanparts.com/uploa...1305064035.jpg
crashr 05-10-2011 08:04 PM
Yes thats the part I'm looking for. I thought it went through the driver side not the passengers. Anyway is there anyway you can measure the inner and outer diamater of the part for me. I'm guessing there won't be a part number stamped on the rubber but maybe you could double check that as well. Thanks again for all this!
JJ 911SC 05-10-2011 08:39 PM
I'll take some measurement tomorrow.
Doubtful about finding a part # on it but we never know... ;)
JJ 911SC 05-11-2011 04:48 PM
Dennis
Almost forgot...
I took 5 measurements. It my be hard to visualize but if you look at the photo, they are almost "natural".
I'll post a photo identifying those measurements tomorrow with a profile of the plug.
# 1 - DME wiring harness; 23mm
# 2 - The sleve on the plug; 32mm
# 3 - The start of the inner plug; 40mm
# 4- Just before the groove (small black band); 53mm
# 5 - The outer flap; 64mm
The groove, just after #4, is about 3mm deep, which would make the hole in the fire wall 50mm
If you make your own plug, the important measurement are #1 and the size of the hole in the fire wall.
Have Fun
JJ
Richard Burns 05-11-2011 05:23 PM
Why not try a local auto electrician or maybe a smash repairer they are liable to have an assortment of the plug that you are looking for jmo.
Richard.
JJ 911SC 05-12-2011 04:54 AM
Dennis
There you go.
If you are not worry about the look, get a 50mm (or slightly larger), drill it to 23mm (or slightly smaller), slipt it in the hole and silicon bead on both side.
If I can re-route the other cable, I'll slide my plug in the hole.
JJ
http://forums.pelicanparts.com/uploa...1305201202.jpg
crashr 05-12-2011 06:02 AM
Hi JJ,
I really appreciate you going to all the effor tto help me out. This forum rocks!
Quick clarification. Wouldn't the size of the hole be 47mm because you were providing me the diameter of the whole, so you need to take 3mm off each side?
I measured the hole that I drilled on my car (for my 3.2 conversion), and it appears to be around 2.25 inchs (57mm). I believe this is the most important measurement. I then used an inner diameter of .0625 inch (1.59mm) for the width of the groove which should give me a good tight fit. I was left with this grommet at this site:
Marco-Rubber
It seems to be about the right ID to allow me to get the DME connector through with still a decent fit. I guess if I dont' hear back from this company (as I only want to buy one) I will just go to home depot and find a generic grommet that I can drill into.
Once again, thanks for all your help on this. I will post pictures of the fix for completion of the thread.
JJ 911SC 05-12-2011 09:21 AM
Yes, 47mm it would be... 53 - (2x3mm)
Measurment 3 to 5 and the groved were rather hard to get (hard to fit the caliper) so I can not gargarente that they are right one, probably within 1mm.
I'll see if I can measure the actual hole.
The Marco stuff would work nicely. If not I would check Lowes (if you got one) before Home Depot. At Lowes, I was able to find S washer in all the metric size.
