911 tweaks's Avatar
smugglers box a/c removal
I am trying to remove such and I have all of the perimeter bolts out & brackets & the 2 a/c lines disconnected & out of the way.
The unit is rotating like a bolt is holding the center of the unit but I cannot find any other bolts...possibly I need to remove the a/c boxes side clips to remove the top of the plastic box?? It appears that I would break the plastic a/c box if I try to remove these side clips on the box...
Any ideas??
Thanks, Bob
I live for 911 tweaks...
Old 09-07-2009, 10:40 AM
My other ride is a C-130J
RNajarian's Avatar
I just removed the smuggler's box A/C unit when I was parting out my '83 SC. It was a PAIN. There is the fan resistor located in the passenger footwell. Be sure to remove the screws and face plate as it connects to the bottom of the unit.
Be careful. The plastic gets old and brittle.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 09-07-2009, 10:47 AM
more PM's than Posts
NY91184's Avatar
I just did this yesturday in my 84 carrera. You remove the 4 10mm bolts to get the top plastic cover off (the one with the 3" hose comming off the top). after the 2 a/c lines are disconnected, lift out the condensor. To get the bottom tray out, remove the wood plank from the pass side footwell and remove the 4 screws that hold the square shaped piece and the tray will lift out. If you need some pics let me know and I can take some. -Brian
Old 09-07-2009, 11:42 AM
pmason's Avatar
Had the same problem, only after I broke did I find out about the connection within the passengers footwell.
Old 09-07-2009, 02:01 PM
911 tweaks's Avatar
Thx RN... that did the trick!
Bob
ps... A complete a/c system up for sale... all components from an 83'SC.
Old 09-08-2009, 03:40 AM
toddu's Avatar
You didn't have to remove the belly pan to get to 1 hose clamp?
Todd
'81 SC
Old 09-08-2009, 06:35 AM
911 tweaks's Avatar
in my case, the belly pan that covers steering rack was already removed.
Thanks, Bob
Old 09-08-2009, 08:29 AM
brooklynporsche's Avatar
BMW Roundel Why remove the smugglers box
Why is this done?
Thanks inadvance
Old 10-03-2009, 09:48 PM
Kraftwerk's Avatar
Weight savings.
People tend to delete their AC systems in these cars, some of which resides in the smugglers box.Most AC systems work poorly and are considered 'dead weight'.
The don't remove the smugglers box just the crap that is in it.
In which case
the foot well screws are good to know about...
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 10-03-2009, 10:49 PM
