My friends call me, Top
Skytrooper's Avatar
2 questions
Background information: 1976 911 Targa 2.7
Questions:
1. Motor will not stay running when cold at idle (which is registering at @500RPM) ?
2. What is the dimension from the center of the windshield frame to the targa bar ?
Thanks in advance !
Matt
'87 924S
Old 10-06-2009, 06:58 AM
Designer King
Paulporsche's Avatar
1. Do a search of your symptoms for a lot of info on this. It is very common w/ these cars.
Probably the single most common cause is an out of spec warmup regulator (WUR) which is causing a too lean mixture during cold starts and warmup.
Another common cause is a vacuum leak. Or your mixture could simply be set too lean.
You should also check out the AAR (auxiliary air regulator) which helps keep revs up during warmup.
Finally, check out Jim Williams. He has a great site on the CIS.
2. I don't know.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-06-2009, 07:32 AM
