10-30 for the winter
the guy at the BradPenn oil supplier says I should use 10-30 for the winter,
and 20-50 only if it's a race car,, which it's not. so I'll be putting in BP 10-30 soon.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
sudo apt-get purge 930
ok
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
15-40 may be more appropriate for your climate - check the manual.
Jerry M '78 SC |
I called back to check,, they only have 10-30, or 20-50, or striaght 30 in BP.
so for now I'll go wit the 10-30, I guess...
No, never use 10w30. Whoever made that recommendation doesn't know a Porsche from a Ford. If you need a winter viscosity and want to use Brad Penn, run a 50/50 blend of 0w30 and 20w50 Brad Penn. That's what I do, since I don't stock their 10w40. Before they started offering a 10w40, their techs would recommend just doing the 50/50 blend like I do and run.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
![]() Charles, are you still running Wicks or have you run across something better. I have been using them since speaking with you last. Thanks for all you impart to the community..
Shane - 1984 928S |
daily driven 911
WIX huh??? ive been using the bosch one.....buuuutttt |
Oh, you are right. WIX... I have a history of misspelling...
![]() My O'Reilly's actually had them in stock without my asking. Strange for Jackson, TN
Shane - 1984 928S |
Yup, Wix/Napa Gold filters are awesome - best bang for the buck. Just as good if not better than the Mahle filters.
Porsche recommended 30w Shell Oil back in the early days. If it was good enough for Porsche its good enough for me
Member #750 Early911S Registry 1970 911E I know Where Jerry S. has his NYC Garage Yadda Yadda Yadda |
Things have changed.......
In the good old days ('50's) we used to play with liquid mercury from broken thermometers. My father was a brilliant doctor and mother was a pharmacist, and people didn't know about carcinogen. DDT was sprayed in homes to kill mosquitoes, agent orange to de-foliage forest, lead paint used in baby cribs, etc..........things changed. Tony |
now what should I do.?
I sent my son to go pick up the 10-30 today, and just got home and read these posts. So, do I send him back, and exchange for 20-50 and use that for the winter too? I will drive the car on cold days, just not snow, if I can manage not to. I was planning to buy 20-50 like all the long discussions here say to, but then got off track by the oil guy. Will the 20-50 be the best choice for winter, too? Or blend some 10-30 and some 20-50? Like go exchange half the case of 10-30?
Manassas, VA
His car is a '78 not a 1950. But your point is valid. I would visit my Porsche mechanic and ask him for a winter oil recommendation for your car. He will be the one rebuilding your engine if you choose poorly, not the Brad Penn dude.
Asking an oil retailer which engine oil to use is like asking the maker of the stethoscope if you have a heart murmur. Mark
1991 964 Polar Silver Metallic Turbo Coupe |
I AM my porsche mechanic. that's the issue I guess. just 20-50 would be my call.
Manassas, VA
Scot,
Sorry, nothing personal but I should have been more clear. Ask a local porsche mechanic who has seen the damage and rebuilt several 1970's Porsche engines because the owner used the wrong oil for the season. You might have to go to Weinmeister's on Camino Del Monte Rey or you could call the Porsche dealer in Albuquerque. Leverage the experience of others, it's usually free. Good Luck, Mark
Unless you are driving a Ford in Alaska, you don't need 10/30. The young guys at parts counters seem to have been trained to guide people to 10/30. They are wrong for cars such as Porsche and many other cars too.
Edit: The same guys try to steer you to Fram filters as well usually
Too many cars, not enough moolah... Last edited by davidbir; 10-08-2009 at 08:04 PM.. |
If you have some 20w50 Brad Penn still, just do a 50/50 blend with it. You'll net a 15w40, which should be good for down to 10F, no problem.
that sounds like a good plan.
I don't have any 20-50 on hand, but I'll see if I can exchange half the case of 10-30 for 20-50. Thanks for your input.
and Mark, how do you know so much about Santa Fe? Or did you just google search? I was impressed. thanks for your help, too.
Ok, so, similar situation, I just bought some 20w50 today for an oil change shortly. It's getting down into the 40's lately, and will only get colder here through the winter. Do I really need one type of oil for the summer and one type for the winter?????
88' Carrera, Black/Black/Black, "Murdered Out" OEM. 06' BMW 'M' Roadster (Wife's car and WAY faster than mine) |
