just got a voltmeter, now what
I just bought a voltmeter at ace hardware. I'm ready to test.
Can you please review issue below and help me solve new and nagging issue The tach bounces sporatically. Drove from Murrieta to Ventura yesterday and back with no bouncing. Tach bounced during 50% of my driving today. It appears that a good pothole can start it. But after a bit it will settle down. Also the tach will bounce when I turn the lights on or the blinkers. The second problem just came up today. This morning the blinkers worked fine. 20 minutes of driving and then they would not work. Later they started working again and now they dont work. Fuses all seem to be fine. Please help I'll post results quickly. Thank you.
1978 911sc Targa Sold 2001 996 Cab Sold 2006 Cayenne S Silver Wifes Car for sale 2011 Jeep Wrangler Silver for sale 2010 Toyota Prius Black for sale 2016 BMW 328D wagon |
Do you want to fix it or just use your meter?
Do a search of the tach issue. I think it is generally related to worn points. But you could also measure the alternator voltage while driving. Set your meter to DC volts, connect the black to ground, the red to the cigarette lighter and see what voltages you get. Check the ground wires on your turn signals, and the bulb sockets. Last edited by 1990C4S; 10-05-2009 at 05:56 PM.. |
Tach - Remove from dash and make sure all connections are tight.
blinkers - maybe your turn signal switch is on its way out.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
I am terrible with electricity but convinced i can get it.
The tool is a multimeter. at idle i get 13.9 at the cig lighter car off at the battery i get 12 cig lighter holds steady at 13.9 with 2-3k rpm
new to the volt meter , just a guess that you got a multimeter ??
if so set to DC (if it has a range option the lowest option that is above 12v) start off with testing your battery should be in the 12 +/- 1 with engine off check from battery + terminal to - terminal and from battery + term to body ground to check your ground strap ... then you can double check your grounds at the dash , take gauge thru the dash turn meter to continuity and test from ground wire at gauge to body ground , there are multiple spots to ground under the dash ... have fun with the new toy Chris , i have three or four , one in the car , one in the pickup, the good one in the tool box and the spare in the kitchen drawer ...
i knew youd chime in steve
thanks tip for removing the tach?
harbor freight they have a "dash tool" set its 4 pieces of nylon like plastic in shapes to help with interior trim removal with out gougeing and cutting ... place at six a clock and start the gauge out under the lip but watch the dash, then 9 o clock then 3 O'Clock be patient and work slow i wouldnt use metal some say a screwdriver but that scares me here are links to tech center that describe it a bit more , or give me a call or ??
check first part of this Pelican Technical Article: Gauge Face Replacement or here http://www.pelican parts.com/techarticles/bob_tindel/brighter_instruments.htm glad you got the car back from the Doctor's have fun with it i still owe you those pics |
i checked the continuity from the tach ground to ground spot in car. measured 0 ohms.
They need to figure out a better way to pull that tach. Engine appears to be running terrific by the way. almost 500 miles since friday
Seems just right to me. Not the issue. Points is my guess....
agree points , you get to learn a new word dwell meter ...
Buy one of those cheap digital voltmeters that plug into your cigarette lighter. Keep an eye on it while driving around. The voltage should be 12.9 to 13.3 or so. Take a good look at it when the tach starts bouncing.
Guessing the alternator is going.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
that plug in voltmeter is available at H-frieght for about 6 bucks you have to adjust the ground out a bit as the early Porsche lighters are a bit larger than the standard (the metal bump on the side)
have a good night Chris , check in on you tomorrow ... ![]()
good deal
heading to get a mobile meter tomorrow. that seems like a good idea as it happens randomly
the harbor freight i went to didnt have the mobile volt meter.
try again tomorrow this sucker has been bouncing on and off for 3k miles maybe im pressing my luck.
okay a couple of "points "
a 78 sc doesn't have any ... The regulator could be going bad or the alternator .. if it is original the regulator is in the left rear engine bay and can be swapped independantly of the alternator. If the car has been updated the regulator is part of the alternator and should just be rebuilt as a unit. if you swap the regulator and it still does it, it could be the alternator . Before doing all this check your connections to the battery and all the ground in the car. also check the connections around the ignition module. Good luck
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
BTW pulling the tach is easy , pull the clock put your hand through the hole and push out the next guage over etc. usually the clock pulls out easiest.
if I remember I think you have to pull the wheel however to get the tach out if it is a stock wheel with no extention
Happiest when Tinkering
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Band.
I was going to say you're going to have a hard time buying POINTS for an SC, but the iceman beat me to it.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
oops I have a 77 motor never paid any att. to an SC ignition no wait a min. I dont have any points either.....now. Im so confused!
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me Last edited by gsmith660; 10-06-2009 at 07:05 PM.. |
gsmith
you nailed the blinker issue i played with the emergency blinker then the regular blinkers started working properly. what is the component i would want to replace to avoid that in the future?
