-   -   help identifying part (pic included!!!) (http://forums.pelicanparts.com/porsche-911-technical-forum/503518-help-identifying-part-pic-included.html)
kidrock 10-06-2009 05:40 PM
had the interior panel off of my passenger door while doing some repairs, when I found this little beauty rolling around loose at the bottom interior of the door.
Ideas? :D
http://forums.pelicanparts.com/uploa...1254876051.jpg
theiceman 10-06-2009 05:50 PM
..it looks like a dime :)
racer 10-06-2009 05:52 PM
naaahh it's a Nickel silly ;)
robmog 10-06-2009 05:56 PM
piece
it looks like part of the window crank mechanism.
thanks to darryld for picture.
http://forums.pelicanparts.com/uploa...1254876910.jpg
Rot 911 10-06-2009 05:56 PM
Part of the window regulator. If your window still goes up and down it has been replaced and that is the old part that the previous owner didn't bother to find and throw away.
kidrock 10-07-2009 09:43 AM
congratulations to racer, it is indeed a nickle!!!
and an additional thanks to robmog and Kurt V for the other thingy. I've found a few "leftovers" from the PO. What was this guy possibly thinking?
Pazuzu 10-07-2009 10:13 AM
Don't blame the PO yet...
That piece is from a different year than the picture, I've circled where it normally lives. When it breaks off (as they do), the spring snaps around and rests against the post just below there. The window still works, and usually no one knows anything broke. I found the exact same piece floating around in the bottom of my door.
http://forums.pelicanparts.com/uploa...1254935592.jpg
ianc 10-07-2009 02:22 PM
Not necessarily. The piece pictured in post #1 looks like a sideways shot of the bit holding the center of the spring, to the SE of the circle above. It does NOT look like what's circled...
ianc
Pazuzu 10-07-2009 02:48 PM
ianc
Yes, and it was changed at one point such that there were two pieces that matched what is in the middle. It then breaks off. If the central piece broke off, you'd be in a world of hurt.
pete3799 10-07-2009 03:02 PM
The broken part in the OP's post is the pivot pin that's holding the center of the spring in the above picture. There are two diferent styles available, make sure you order the correct one.
Our host has them.
RWebb 10-07-2009 03:07 PM
right - they fail fairly often (or the rivet or crimp that holds it in fails) and I've seen several posts titled 'what is this?'
search up some threads on what else to do while you have the door apart - I know I've seen a nice list somewhere
kidrock 10-07-2009 03:43 PM
knock on wood, everything works well for now...oh, except maybe the power mirrors. Another project down the road. I think next time I go back in there, I'll be replacing the door stops. And swapping out the plastic door handles for the aluminum ones. And...and...and...............
RWebb 10-07-2009 03:52 PM
at least clean out the crud from the bottom; check the drip holes; & check for rust with light and mirror
rnln 10-07-2009 05:33 PM
Funny, I found the same thing inside my passenger door couple days ago; while working on my door lock. I knew what it is but too lazy/tired to make sure if my was replaced, and assumed it did (window is still working).
JJ 911SC 10-07-2009 06:30 PM
Mirrors problem???
Stone
What wrong with your mirrors? Mine stop working after the Babe become airborne going over some &^$#@* badly laid railroad tracks.
Since both of them could not be adjust, I was hoping for the usual "blown fuse" or even better "fuse pop out" but no such luck.
After attending more pressing problem such as; reassuring the wife that she has not been replace by the Babe... and I would start on the Spring/Summer "honey do" list as soon as Winter comes around, I decided to take a look at the Adjusting Switch on the driver side door.
As soon as I removed the top of the door (1 screw & 1 nut), I notice that there was nothing hook up to the switch... Came apart when I flew over those &^$#@* tracks. Plug it back and Voilas... both mirrors are working and everybody is happy, well I think the wife is still P.O. (her fault anyway).
Bonne Chance
J.J.
kidrock 10-08-2009 03:15 AM
you're lucky...I have a different issue. Both mirrors work, but poorly. Won't move in certain directions. Maybe need to clean up some connections in there?
