muck-raker
kidrock's Avatar
help identifying part (pic included!!!)
had the interior panel off of my passenger door while doing some repairs, when I found this little beauty rolling around loose at the bottom interior of the door.
Ideas?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-06-2009, 05:40 PM
theiceman's Avatar
..it looks like a dime
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-06-2009, 05:50 PM
racer's Avatar
naaahh it's a Nickel silly
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-06-2009, 05:52 PM
robmog's Avatar
piece
it looks like part of the window crank mechanism.
thanks to darryld for picture.
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 10-06-2009, 05:56 PM
Friend of Warren
Part of the window regulator. If your window still goes up and down it has been replaced and that is the old part that the previous owner didn't bother to find and throw away.
Kurt V
muck-raker
kidrock's Avatar
congratulations to racer, it is indeed a nickle!!!
and an additional thanks to robmog and Kurt V for the other thingy. I've found a few "leftovers" from the PO. What was this guy possibly thinking?
STONE
Old 10-07-2009, 09:43 AM
Don't blame the PO yet...
That piece is from a different year than the picture, I've circled where it normally lives. When it breaks off (as they do), the spring snaps around and rests against the post just below there. The window still works, and usually no one knows anything broke. I found the exact same piece floating around in the bottom of my door.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-07-2009, 10:13 AM
ianc's Avatar
Not necessarily. The piece pictured in post #1 looks like a sideways shot of the bit holding the center of the spring, to the SE of the circle above. It does NOT look like what's circled...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-07-2009, 02:22 PM
ianc
Yes, and it was changed at one point such that there were two pieces that matched what is in the middle. It then breaks off. If the central piece broke off, you'd be in a world of hurt.
Mike Bradshaw
Old 10-07-2009, 02:48 PM
pete3799's Avatar
The broken part in the OP's post is the pivot pin that's holding the center of the spring in the above picture. There are two diferent styles available, make sure you order the correct one.
Our host has them.
Pete
79 911SC RoW
Old 10-07-2009, 03:02 PM
AutoBahned
RWebb's Avatar
right - they fail fairly often (or the rivet or crimp that holds it in fails) and I've seen several posts titled 'what is this?'
search up some threads on what else to do while you have the door apart - I know I've seen a nice list somewhere
Old 10-07-2009, 03:07 PM
muck-raker
kidrock's Avatar
knock on wood, everything works well for now...oh, except maybe the power mirrors. Another project down the road. I think next time I go back in there, I'll be replacing the door stops. And swapping out the plastic door handles for the aluminum ones. And...and...and...............
STONE
Old 10-07-2009, 03:43 PM
AutoBahned
RWebb's Avatar
at least clean out the crud from the bottom; check the drip holes; & check for rust with light and mirror
Old 10-07-2009, 03:52 PM
rnln's Avatar
Funny, I found the same thing inside my passenger door couple days ago; while working on my door lock. I knew what it is but too lazy/tired to make sure if my was replaced, and assumed it did (window is still working).
Fat butt 911, 1987
Old 10-07-2009, 05:33 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest Mirrors problem???
Stone
What wrong with your mirrors? Mine stop working after the Babe become airborne going over some &^$#@* badly laid railroad tracks.
Since both of them could not be adjust, I was hoping for the usual "blown fuse" or even better "fuse pop out" but no such luck.
After attending more pressing problem such as; reassuring the wife that she has not been replace by the Babe... and I would start on the Spring/Summer "honey do" list as soon as Winter comes around, I decided to take a look at the Adjusting Switch on the driver side door.
As soon as I removed the top of the door (1 screw & 1 nut), I notice that there was nothing hook up to the switch... Came apart when I flew over those &^$#@* tracks. Plug it back and Voilas... both mirrors are working and everybody is happy, well I think the wife is still P.O. (her fault anyway).
Bonne Chance
J.J.
Who Will Live... Will See
Old 10-07-2009, 06:30 PM
muck-raker
kidrock's Avatar
you're lucky...I have a different issue. Both mirrors work, but poorly. Won't move in certain directions. Maybe need to clean up some connections in there?
STONE
Old 10-08-2009, 03:15 AM
