Optional heating (72)
I have noted that there are "vented" and "non-vented" tunnel covers (rear area over shift rod coupling). The parts cat. Suggests that the vented unit is for optional heating. How does one know (other than pouring on the heat)? Or is there another reason for the venting?
The early cars could have an optional gasoline-fired Webasco heater located in the smuggler's box. The heat is ducted through the round, capped, tube at the lower right of the box. That tube is a direct connection to the tunnel where the heat would exit through the rear vented cover.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
It has been a while since I have looked at one of these Webasto heaters. My '67 had one in it. IIRC the vented rear tunnel cover was for the air intake. The gas heater then blew the heated air through the vent system.
FC '73 911 Track Car '99 996 Daily Driver '93 968 Wife's Car '05 Cayanne S Family Car Last edited by Fast Corners; 10-08-2009 at 03:37 PM.. |
thanks, i now know i do not need a vented cover.
I never had one so even as I typed I was a little unsure.
