| Bill Verburg |
10-14-2009 02:39 PM |
Originally Posted by Mr_SpongeWorthy
(Post 4952766)
Back again. It turns out that my "baseline" car does indeed have the turbo tie-rod modification. So unfortunately this doesn't give me a very clear idea of the differences I should feel between the SC and the Carrera in stock form. I'll be test driving a stock SC sometime next week though, so that should give me some further insight. I have to say I haven't been overwhelmed by the Carrera "road feel" so far. I'm thinking I might be better off sticking to the SC series.
the suspension design on all '69 -89 911 is the same, differences in feel come from components, component condition and alignment.
For sporting feel, the 'live steering wheel' you want Bilstein shocks, turbo tie rods, 7 & 8" wheels(min), quality performance tires and quality performance setup. Of course the condition of all components needs to be nominal.
The lively feel comes form a combination of built in bump steer, steering axis inclination and scrub radius.
You can never get rid of all bump steer just minimize it, which factory alignment and height specs do, steering axis inclination is the result of front end geometry and caster settings, scrub radius is increased on an 8 vs a 7 vs a 6 the larger scrub radius increases wheel feedback through the steering.
If I were shopping for an '80s 911, I'd look for in order '87 -89, '84-86, then '78-83
