Mark S
Getting vent window out of frame?
Pulled down window frames for re-chrome now can't figure out how to get wing window glass out of frame. I oiled, soaked in mineral spirits, pulled etc. Wing is 67 911 any suggestions appreciated.
Never have removed one of those, but I might try removing as much of the old rubber as I could with a razor blade & trying: WD-40, penetrating oil, silicone? Probably somebody else will respond with how its done. Good luck.
Marv Evans '69 911E |
Mark S
The trick was heat from a plumbers torch on the frame. Not much but hot enough you would burn yourself W/O HD gloves.
