Throw it on the ground!
Paint recommendation for engine shroud?
Will be removing intake this weekend to replace all gaskets and spacers to fix intake leak. Thinking about removing and repaiting the shroud while I'm at it. What type of paint have people used?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
As long as you prep with a plastic primer it will come up fine. I did mine with plastic primer and a 2k paint.
Adam ![]()
Adam Bloomer certified Porsche tragic 83 SC (project)07 Boxster S My wife says I am married to my cars, which makes her my mistress.....I can live with that!!! |
Wow Adam
That should be in a glass case in the living room. Nice!
1978 911sc Targa Sold 2001 996 Cab Sold 2006 Cayenne S Silver Wifes Car for sale 2011 Jeep Wrangler Silver for sale 2010 Toyota Prius Black for sale 2016 BMW 328D wagon |
Almost Banned Once
Just about any good quality heat resistant paint will do...
Just one thing. You need to get it very clean before you paint it. When I did mine I got "fish eyes" all over it even after cleaning it with acrylic thinners. You could try some Marine Clean from POR15 to get it really clean before painting. POR15 also sell heat resistant paints. MARINE CLEAN-POR-15 Inc.
- Peter |
Friend of Warren
No need for plastic primer. The shroud is fiberglass so you can use any quality primer and paint.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Roland 930 Turbo '81 Too many modifications to list |
Band.
I used GLOSS BBQ paint from my local hardware. It looks okay but isn't very scratch resistant. wiring harness and spark plug wires did a number on it.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Less brakes, more gas!
Engine Shroud Painting, Help! - Pelican Parts Technical BBS
Best paint long term for fan shroud? Krylon? Plastikote? Enjoy! -Michael
![]() ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
PS: remember that the shroud is dyed FG so you will not get a factory look back once it is painted. You can lightly wet sand small scratches out and clean the hell out of it and it will return to some resemblance of new depending on the beginning condition. Outside of that... there is not much to do, but paint it.
-Michael
Phew!!! I am not the only one to have crap in my house.
Try this....four fuchs in the master bedroom
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
I painted my engine shroud with the epoxy primer and single-stage acrylic enamel tangerine color that I used to paint the car. I wanted a smooth look so I color-sanded it and buffed it out. It still looks like new after 4 years.
Rod ![]() |
a.k.a. G-man
Mthomas58, What color are you going to paint??
Hotrod, Nice looking engine!!! Did you paint the fan or powdercoat?
Сидеть, ложь, Переворачиваться |
VHT paint works really well too. Good to over 2000 degrees and meant for exhaust. Works great on the underbody to prevent rust (is also salt resistant).
Color: paisley or plaid ![]()
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
Geronimo,
I painted the fan with Rust-Oleum Professional stainless steel paint in a spray can from Lowe's. I think it actually has stainless steel particles in the paint because it is very resistant to heat and has a nice natural stainless appearance. I use it on brake calipers, engine parts, bolts, and anything else that I don't want to rust. It goes on any type of material and seems to last a long time. Rod |
AutoBahned
Best would be to sand with fine grit then use a rubbing compound on a buffer, NOT paint.
if you do paint use a FG paint or add flex agent - it will never look as real as a restored FG one. mine is painted tho. |
I'm planning on just refreshing the existing black color with paint. Tyson Schmitt recommends krylon fusion paint and since I already have some I'll probably go with that. I might try some polishing compound on my 3" random orbital buffer first to see how it looks before resorting to paint.
