Throw it on the ground!
Paint recommendation for engine shroud?
Will be removing intake this weekend to replace all gaskets and spacers to fix intake leak. Thinking about removing and repaiting the shroud while I'm at it. What type of paint have people used?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 10-08-2009, 04:58 AM
OZ911SC's Avatar
Thumbs up
As long as you prep with a plastic primer it will come up fine. I did mine with plastic primer and a 2k paint.
Adam
Adam Bloomer
certified Porsche tragic
83 SC (project)07 Boxster S
My wife says I am married to my cars, which makes her my mistress.....I can live with that!!!
Old 10-08-2009, 05:09 AM
chocolatelab's Avatar
Wow Adam
That should be in a glass case in the living room. Nice!
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 10-08-2009, 05:14 AM
Almost Banned Once
sc_rufctr's Avatar
Just about any good quality heat resistant paint will do...
Just one thing. You need to get it very clean before you paint it.
When I did mine I got "fish eyes" all over it even after cleaning it with acrylic thinners.
You could try some Marine Clean from POR15 to get it really clean before painting.
POR15 also sell heat resistant paints.
MARINE CLEAN-POR-15 Inc.
- Peter
Old 10-08-2009, 05:20 AM
Friend of Warren
No need for plastic primer. The shroud is fiberglass so you can use any quality primer and paint.
Kurt V
Old 10-08-2009, 06:14 AM
proffighter's Avatar
Originally Posted by chocolatelab View Post
Wow Adam
Livingroom is a good idea
Roland
930 Turbo '81 Too many modifications to list
Old 10-08-2009, 07:55 AM
Band.
I used GLOSS BBQ paint from my local hardware. It looks okay but isn't very scratch resistant. wiring harness and spark plug wires did a number on it.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 10-08-2009, 08:06 AM
Less brakes, more gas!
euro911sc's Avatar
Engine Shroud Painting, Help! - Pelican Parts Technical BBS
Best paint long term for fan shroud? Krylon? Plastikote?
Enjoy!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-08-2009, 08:07 AM
euro911sc's Avatar
PS: remember that the shroud is dyed FG so you will not get a factory look back once it is painted. You can lightly wet sand small scratches out and clean the hell out of it and it will return to some resemblance of new depending on the beginning condition. Outside of that... there is not much to do, but paint it.
-Michael
Michael
'13 Cayenne GTS
Old 10-08-2009, 08:09 AM
ShakinJoe's Avatar
Phew!!! I am not the only one to have crap in my house.
Try this....four fuchs in the master bedroom
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 10-08-2009, 09:25 AM
Hotrod911T's Avatar
I painted my engine shroud with the epoxy primer and single-stage acrylic enamel tangerine color that I used to paint the car. I wanted a smooth look so I color-sanded it and buffed it out. It still looks like new after 4 years.
Rod
Old 10-08-2009, 09:47 AM
a.k.a. G-man
Geronimo '74's Avatar
Mthomas58, What color are you going to paint??
Hotrod,
Nice looking engine!!!
Did you paint the fan or powdercoat?
Old 10-08-2009, 10:56 AM
docrodg's Avatar
VHT paint works really well too. Good to over 2000 degrees and meant for exhaust. Works great on the underbody to prevent rust (is also salt resistant).
Color: paisley or plaid !
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Hotrod911T's Avatar
Geronimo,
I painted the fan with Rust-Oleum Professional stainless steel paint in a spray can from Lowe's. I think it actually has stainless steel particles in the paint because it is very resistant to heat and has a nice natural stainless appearance. I use it on brake calipers, engine parts, bolts, and anything else that I don't want to rust. It goes on any type of material and seems to last a long time.
Rod
Old 10-08-2009, 11:16 AM
AutoBahned
RWebb's Avatar
Best would be to sand with fine grit then use a rubbing compound on a buffer, NOT paint.
if you do paint use a FG paint or add flex agent - it will never look as real as a restored FG one.
mine is painted tho.
Old 10-08-2009, 11:48 AM
Hotrod,
I'm planning on just refreshing the existing black color with paint. Tyson Schmitt recommends krylon fusion paint and since I already have some I'll probably go with that. I might try some polishing compound on my 3" random orbital buffer first to see how it looks before resorting to paint.
Mark
1987 911 Coupe
Old 10-08-2009, 12:07 PM
