Best Satin black for wheels and trim?
I need to redo the black centers on my fuchs and possibly the trim where it is wearing off on the car. What has been found to work out well? I seen to remember one product, Wurth? And is that in Satin Black?
Randy
73.5 911 T
97' C2S
06' C2S
Old 05-02-2011, 06:52 PM
Checked out
McLovin's Avatar
I've used all sorts of Satin paint on Fuchs over the years.
Wurth Satin is IMO the best, the easiest to use (flows the best), matches the factory look the closest (although some others are close, too), and lasts the longest. It is a very high quality paint, worth the extra $5-$10 it will cost you, IMO.
Old 05-02-2011, 06:55 PM
Super_Dave_D's Avatar
Home Depot - Rustoleum 7777
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 05-02-2011, 07:00 PM
RETIRED
Joe Bob's Avatar
That or Wurth Satin Black.....
2012 ML350 3.0 Turbo Diesel
Old 05-02-2011, 07:02 PM
Registered Misfit
Mark Morrissey's Avatar
Wurth is the best in my opinion
Instagram: mark0morrissey
Website: www.markmorrissey.org
911 hotrod -- 3.2L, short stroke, twin-plug. Elephant Racing Turbo brakes, Tarrett suspension. Lightened, abused with love
Old 05-02-2011, 07:24 PM
Carrera3.2LG50's Avatar
I painted my Fuchs centers about a year ago. I read tons of posts on it and found many different opinions on paint, but I decided to go with the Wurth Satin Black.
Here's an example of a freshly painted wheel using Wurth:
Old 05-02-2011, 07:31 PM
80-911SC's Avatar
rustoleum 7777 .. not Fuchs but 2 years on the road and still nice ...you get the idea .
a bit dirty but ???
Old 05-02-2011, 07:47 PM
AUS911SC3's Avatar
I've used all, I found Satin Black VHT polyurethane wheel paint best , as far true to colour and paint strength.
Old 05-02-2011, 08:29 PM
D911SC's Avatar
Did you bake it after it dried? When testing the product I've found it marks easily but there are many fans of this product. I admit that I never baked it so this might make all the difference.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 05-03-2011, 04:00 AM
Mo money = mo parts
I have used plain old Rustoleum satin black on several of my trim pieces. I swear, you can not distinguish it from any oem colors. I would recommend a trip to Lowes or Home Depot and investing in a $5 can, then make your own decision.
Also, I would recommend purchasing thin blue vinyl trim tape from 3M. It makes it very easy to lay down a clean perimeter line. Masking tape is more difficult to create the edge. My tape is about 1/4" wide. I read about it in someone's post, make it a lot easier.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-03-2011, 06:04 AM
+1 on that.
I first used the 1/4" and then the 3/4" blue vinyl tape to mask the wheel perimeters.
After that I used a combination of masking tape and paper. But the flexible blue tape made my life a lot easier.
Old 05-03-2011, 08:02 PM
Techne's Avatar
Prep by buffing with steel wool. I used small balls of the stuff to plug the lug holes to keep paint out of that area. I used Rustoleum 7777 - several thin coats - and three years later with daily use and pacific northwest rain and muck and they still look great. Go for it!
Old 05-03-2011, 08:45 PM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
I have used Duplicolor Wheel paint available at pep boys. Good stuff. used on wheels and trim.
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 05-03-2011, 10:55 PM
D911SC's Avatar
It's a shame 7777 is not available in Australia, otherwise I would have bought some long ago.
Old 05-04-2011, 12:50 AM
I wrapped 5 lug nuts with aluminum foil and placed them over the lug holes.
(Not my idea - got that tip from one of the forums - worked great.)
Old 05-04-2011, 07:24 PM
D911SC's Avatar
Managed to sneak this in last night while the wife wasn't looking (hence the dodgey phone camera pic)!
Baking has made a huge difference to the hardness of the finish. If you buy a rattle can that suggests baking it to fully cure then I would suggest you do it.
BTW this is VHT Engine Enamel. I was going to send them off for 2K paint but wanted to test this product first (I only painted the rear of the wheel so far). A rattle can appeals to me because it can be touched up easily plus I have found the VHT so easy to use. Getting an even, satin finish from 2K in my backyard was not in my skillset. I know VHT has a Wheel Paint (which I have tried) but I like the idea of a tougher paint which the Engine Enamel is.
As a rattle can paint I know that with no hardener certain chemicals can ruin it, but my 911 is not a DD and the wheels will only be washed by me with warm water and a dash of light detergent.
Old 05-04-2011, 11:24 PM
I use Eastwood Satin Black Wheel Paint #10085Z.. As far as baking, I leave them in the SC sun for a couple days.. That'll about bake anything..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 05-05-2011, 10:00 AM
1984 Targa Carrera
Does anyone have an idea of how much paint it takes to paint all four wheels?
1984 Carrera Targa
Old 04-16-2013, 02:52 PM
abisel's Avatar
Has anyone ever considered the two-part coatings used in firearm finishes?
DuraCoat:
DuraCoat Firearm Finishes
Cerakote:
Cerakote Coatings
I am using DuraCoat to restore an old Marklin HO scale model locomotive. So far it appears to be as advertised.
This might be a good product for such applications as wheels. Not to mention other things.
Old 04-17-2013, 06:46 AM
PPG Black epoxy primer... DP90LF. It's a very nice satin, and it will not wear off. But you need to mix it and run it through a sprayer - and wear a mask!
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 04-17-2013, 05:14 PM
