85 Targa
BrianW-n-SC's Avatar
What is the best oil to use?
Also ??? 10W 30 or what. I live in South Carolina (weather temps are mild)
Winter low maybe 20's
Summers 105 max
Old 10-14-2009, 04:56 PM
Yea that should be fine, thats what I use, Conventional for my 69, im in NoCal. Do a search on this site about this. Be warned thou you may be more confused after.
1972 911T MFI
1995 911 C2
Old 10-14-2009, 05:05 PM
That's the simplest question that you could ask on this site, with the most complex answer. Particularly since nobody has any idea what 911, in what state of tune, for what purpose, including what kind of oil has been in the car previously, that you're talking about.
'85 Targa I'm assuming, casual and occasional everyday driving, nothing stressful, just puttin' around? You could almost say "Any good, modern oil above lawnmower-grade." 30-weight's sort of thin for an air-cooled engine, though.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-14-2009, 07:01 PM
brads911sc's Avatar
Protechnik here in Houston (The premier Porsche shop here and the largest in the Southwest) uses Royal Purple and Mobil 1 for syn and Valvoline for Dino. Two other well regarded shops (EuroCarWerk and European Auto Technik) both use Mobil 1 for Syn. Eurocarwerk uses Castrol for Dino. Lots of opinions. But these three shops probably control 75% of the enthusiast market here in Houston. There are lots of threads on this including the ultimate oil thread.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 10-15-2009, 09:46 AM
Bill is Dead.
cashflyer's Avatar
Where in SC are you located?
There are quite a few of us in the upstate.
I use Amsoil Series 2000 20-50 racing oil. They don't make it any more, and I'm on my last case now. When it is gone, I will use their Dominator 15-50 Racing oil. Both are 100% PAO synthetic with good zddp content.
Old 10-15-2009, 10:22 AM
I suspect the reason you're getting so few responses is that everybody is tired of dealing with this question. Do a search and you'll find every kind of advice from using super-rare racing oils to "Mobile 1,"as most people seem to spell it, like it's a cellphone. As I said earlier, the bottom line for a standard, ordinary, conventionally driven 911 is "any good oil," though there are people who will insist that your car will self-destruct unless you use 13 quarts of $30-a-bottle hyperbrew and change it every 1,000 miles.
But do go with a 50-weight, not 30.
Stephan Wilkinson
Old 10-15-2009, 02:35 PM
Frosty the A.I.
Wintermute's Avatar
I use Valvoline VR-1 Racing oil, 20w-50. I have been pretty happy with it and it's not that expensive, around $5 a quart (it's Mineral). It also has ZDDP and Ashless additives for better protection.
Old 10-15-2009, 02:56 PM
myamoto1's Avatar
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
That should keep you busy for a while. Harry's first post has a good summary of what's been determined "acceptable"
Josh
85 M491 Coupe - "Fat Bastard"
Old 10-15-2009, 03:11 PM
VR1 Valvoline is a fine oil to use. multi viscosity 30 weights are not. HTHS spec needs to be higher than 3.5...Very few 10w30's are going to meet that spec. run a good xxw40 or xxw50 in the air cooled 911's.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 10-15-2009, 04:04 PM
boxster03's Avatar
I just checked my owners f*%^ and 30w Shell is recommended. Now if there is a problem because of the oil and the recommendation from Porsche I know who I will sue
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 10-15-2009, 05:24 PM
Boxster manual or 1970 911E manual?
Stephan Wilkinson
Old 10-15-2009, 06:19 PM
