my radio cuts when I turn left???
hI
MY CAR IS A 89 . When i turn left like going on a ramp the radio cuts off but the radio light is still on just no more sound ,is there any wirering around the steering wheel related to the radio?I have a stock amp under the seat.
Old 10-20-2009, 08:48 PM
steely's Avatar
Can't sleep tonight, so I'll take a stab.
Guess we can eliminate radio power (lite on), and I'm not aware of any radio wiring in the column. That leaves the speakers, amp/power, and antenna.
Make sure the antenna connection isn't loose in the back of the radio/chk leads at antenna while yer at it (window or aerial).
Doubt all speakers/wires go, so the common point may be the amp.
Does it have a light pwr you can see ? tricky
Only thing left short of a problem in the radio itself (no pun intended), would be the power lead to the amp (is it for all channels?). see if it's loose or if it was added (although you did say stock), maybe a separate line was added to it (under hood near batt or at the amp).
Does your radio have a headphone jack (unaffected by the amp) you could test?
CD player or anything else do the same thing?
good luck.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-20-2009, 11:12 PM
Mitch Leland's Avatar
Does it stop working on both radio and CD? If it's only the radio maybe there's an antenna problem? I don't think there's any wiring around the steering wheel that would cause this.
Suggest you put your car up on stands and see if you can replicate the problem...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 10-20-2009, 11:15 PM
It's Rush Limbaugh extending his control of the airwaves.
Old 10-21-2009, 06:49 AM
nineball's Avatar
I am going to put the blame on a loose connection at the amp, either power, ground or input signal. Just guessing I would say that the connection is loose and the slight g-forces of turning cause it to disconnect enough to stop working.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 10-21-2009, 10:51 AM
Air Cooled Addict
Joe V's Avatar
How secure is your battery?
Make sure your positive terminal isn't making intermittent contact to body ground. If the battery isn't properly braced, it can shift and cause the radio to cut out. Don't ask me how I know...
Joe V
'84 Schwartz 911 Carrera 3.2
'91 Specialized S-Works M2 - Gone but not forgotten
'12 Trek X-Cal : American Classic - XT brakes/shifters/derailleurs - carbon goodies
'13 Trek Madone 5.2 stockish
Old 10-21-2009, 07:31 PM
Danny_Ocean's Avatar
Turning left is so overrated. As does UPS, plan your routes with right turns only.
Seriously, though...look around in the wiring. Something is touching something (or not touching something) when you turn.
Old 10-21-2009, 08:24 PM
PCA7GGR's Avatar
Turn right three time - its safer than turning left. A plus is - your radio won't cut out.
This is what I was taught as part of my drivers safety course when I started working at AT&T a long, long time ago, in a galaxy far, far away.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 10-21-2009, 09:33 PM
