-   -   New tool, guess what it is! (http://forums.pelicanparts.com/porsche-911-technical-forum/506148-new-tool-guess-what.html)
James Brown 10-20-2009 09:01 PM
http://forums.pelicanparts.com/uploa...1256097631.jpg
tell you soon...
Canada Kev 10-20-2009 09:05 PM
Have you used it yet? Does it make adjusting the valves easier?
James Brown 10-20-2009 09:08 PM
no but it should (thanks for letting the cat out of the bag)
Canada Kev 10-20-2009 09:12 PM
Sorry. You DID say to guess... ;)
James Brown 10-20-2009 09:23 PM
yes it is for adjusting valves. using the degree principle.
m110 10-20-2009 09:36 PM
I'd guess the angle represents about a 45 degree arc. If you know pitch of the adjustment screw then you can calculate how much looser or tighter the valve will be. What is the angle supposed to be and thus represent?
Won 10-20-2009 09:46 PM
How will you know where your "zero gap" point is? It's very possible to tighten it until you're actually compressing the valve springs.
James Brown 10-20-2009 09:59 PM
well yes you could, just lightly tighten till it makes contact then note the position of the first arm then turn it to align it to the 2nd arm. that should equal .004mm hold it there and tighten the stop nut, your done!
the angle is 39 degrees
signature65 10-20-2009 10:56 PM
As long as your swivel feel are in very good condition......any wear on them and your adjustments will be off.
Just saying......
James Brown 10-20-2009 11:34 PM
yes you do have to be a mechanic to operate it.
charlesbahn 10-21-2009 06:48 AM
Very clever, I like it.
Charles
theiceman 10-21-2009 09:46 AM
this thing is outstanding .. and wear issues affect both calipers and this tool . Although any indirect measurement will increas error rate . i would say the benefits of this tool outweigh any risks by about ten fold. You are MUCH more likely to make errors with feeler drag than with this tool, especially if you do not have a lot of experience with feeler guages.
Outstanding ....
ClickClickBoom 10-21-2009 10:44 AM
Hey,
Nice screwdriver, I am kinda concerned about those metal holderupper things sticking out of the handle though, not gonna use it in a live junction box, too much chance of sparks. Now who's that P-51 belong to? I would like to offer to "exercise" it for you at a low introductory price though. I am checked out in lots of things from Cubs to being authorized to cross country flight in the X15http://i71.photobucket.com/albums/i1...d/DSC00850.jpg
Scott Crossfield hooked a brother up. Notice I am just adequate, after all the engines are lit, I get a little squirrely.
BAAHAAHAA
eric
bourgeois911 10-21-2009 10:49 AM
Pretty sure those screws are 1.0mm threads so I'll guess 360/10 = 36 degrees to get a .1mm gap.
You're mixing metric and English measurements. .004 mm is a very tiny gap.
.1 mm = .004 inch
Steve@Rennsport 10-21-2009 11:15 AM
Those tools are made by my neighbor & buddy, Tom Bennett. :)
James Brown 10-21-2009 12:30 PM
yes its pretty cool, sorry my Sir tool is not metric? it's .004 inch? oh that makes sence.
DRACO A5OG 10-22-2009 12:17 AM
Does he have a website or can you post his contact info?
James Brown 10-22-2009 12:21 AM
I got mine off the rennlist board, i'll look it up
James Brown 10-22-2009 12:42 AM
Nice click click, "landing at edwards" nice touch, but the CFI didn't put his number down, you will need another check flight!
James Brown 10-22-2009 12:49 AM
here is the URL for ordering:
Valve Adjusting Screwdriver | Tom Bennett Web Strategist
