-   -   AFM spring calibration : i need help please guy's (http://forums.pelicanparts.com/porsche-911-technical-forum/506404-afm-spring-calibration-i-need-help-please-guys.html)
cdrik915 10-22-2009 07:51 AM
Hi !!!
I've got a problem to remember how was the spring calibrated in the AFM .
Can someone explaining me the way to do it with factory values ???
Number of teeth ?
I just talk about the spring , and not found something about it.
Thanks for all input ,
Cheers,
Ced'
T77911S 10-22-2009 10:15 AM
i assume you are talking about an 84 or newer, not a CIS car?
you should post the year and any other info that will help.
Rot 911 10-22-2009 10:55 AM
84-89 all used the same AFM. I even thing the 964's has the same AFM.
Steve W 10-22-2009 11:28 AM
I think you're going to have difficulty setting the spring calibration. The only way I can think of doing this is by a flow bench comparing the output voltage to a calibrated unit.
cdrik915 10-22-2009 09:05 PM
The car is a stock 86' 3.2 model .
I've got the AFM way of calibrating , but that don't talks about the stock calibration of the spring.
Only how to leaning up or leaning down the mixture .
If somebody knows...........Thanks again !!!!
Good day to all !!!
DRACO A5OG 10-23-2009 07:33 PM
Ced,
Post a picture to show what your AFM looks like, maybe we can see the issue and help that way.
I have an AFM that you maybe able to referrence to as well.
rattlsnak 10-23-2009 09:10 PM
mine was messed with by the previous owner and i spent alot of time trying to sort it out, and i finally bought a another one off of here and problem solved. there are a few different markings on the spring and holder and housing, but i wasnt able to find out what they menat so you're shooting in the dark.
cdrik915 10-24-2009 01:08 AM
Originally Posted by DRACO A5OG (Post 4970213)
Ced,
Ok , thanks for the advice , i'm going to do a pics of the AFM.
cdrik915 10-24-2009 04:13 AM
http://nsa10.casimages.com/img/2009/...1224307338.jpg
Here a pic of the AFM.
Thanks.
