AFM spring calibration : i need help please guy's
Hi !!!
I've got a problem to remember how was the spring calibrated in the AFM . Can someone explaining me the way to do it with factory values ??? Number of teeth ? I just talk about the spring , and not found something about it. Thanks for all input , Cheers, Ced'
LIGHTER = FASTER !!! Last edited by cdrik915; 10-22-2009 at 09:32 AM.. |
i assume you are talking about an 84 or newer, not a CIS car?
you should post the year and any other info that will help.
Friend of Warren
84-89 all used the same AFM. I even thing the 964's has the same AFM.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I think you're going to have difficulty setting the spring calibration. The only way I can think of doing this is by a flow bench comparing the output voltage to a calibrated unit.
The car is a stock 86' 3.2 model .
I've got the AFM way of calibrating , but that don't talks about the stock calibration of the spring. Only how to leaning up or leaning down the mixture . If somebody knows...........Thanks again !!!! Good day to all !!!
LIGHTER = FASTER !!! Last edited by cdrik915; 10-23-2009 at 03:57 AM.. |
Member 911 Anonymous
Ced,
Post a picture to show what your AFM looks like, maybe we can see the issue and help that way. I have an AFM that you maybe able to referrence to as well.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Insert Tag Line HERE.....
mine was messed with by the previous owner and i spent alot of time trying to sort it out, and i finally bought a another one off of here and problem solved. there are a few different markings on the spring and holder and housing, but i wasnt able to find out what they menat so you're shooting in the dark.
Ok , thanks for the advice , i'm going to do a pics of the AFM.
LIGHTER = FASTER !!! |
![]() Here a pic of the AFM. Thanks.
