Change alternator belt in 5 seconds ?
I did not see this posted yet, pretty good !
YouTube - Volkswagen Generator Belt Wonder if anybody would like to try it on the 911 ;-) |
Checked out
LOL, that was pretty good, esp. the removal part.
I used to do something like that on my old 914s. Except cut the belt off (while the car isn't running!), slide the new one on as far as it could go, then start the engine and voila, the belt pulls itself into place. |
Had I only known, I would have saved myself 5 minutes of my time. I replaced the belt on my 87 911 this weekend. That would not (or could it?) work on a belt with the proper tightness.
1987 911 Carerra Coupe 2006 VW Jetta TDI two german black beauties
That looks like a great way to loose a finger or two.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Ohhh Noooo, I really wish a had not watched that. Guess what my next project is.....
It does work on properly tightened belts. I have seen other looneys do it on 911s and Mercedes but only putting it on by starting the engine.
1988 Carrera Coupe |
Navin Johnson
Yes, I have cut a belt off, an rolled a new belt on...
Not on a running engine... I either turned the engine over by hand, or cranked the starter to get the new belt on
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
asking for trouble.....
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Hey, in no way do I condone this either, but I thought it was worth posting - it's funny... Probably takes a loose belt to begin with, and the new one may not last as long as it should either !
Almost Banned Once
Very slick...
You couldn't do that on a Porsche you cared about but on an old VW... Why not?
- Peter |
A friend of mine was working on a VW motor, the owner was in the car, my friend yelled: "do not turn the motor over." So what happens, my friend checks the belt, owner turns engine over, friends finger wraps around the pully.
72 911 Although it is done at the moment, it will never be finished. |
Almost Banned Once
Ouch!
- Peter |
