Ruby911
Combining Oil Viscosities??
This may well be a really dumb question, but what would be the impact of topping off oil that is filled with 20W50 with something other. Obviously, this is not ideal, but if in a pinch and had to do it, is there any residual effects?
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Make My Day
I think that you would want to use the same brand and formula at the very least to help assure the two will mix.
74 911S Targa ROW Building Designer/Business Owner |
It won´t effect the motor. Its would be ideal to keep to the oil recommended for you motor but a blend is better than too much or little of any oil. The viscosity number represent cold and warm characteristics of the particular oil used. Topping up 20 W 40 with 10 W 40 will have no negative effect. A regular oil change is the most important part of motor care
Nope- very safe. Especially in a 911 where you're mixing into a lot of volume.
Ruby911
Thanks Paul
Make Bruins Great Again
Per Brad Penn Rep: If you put in 5 qts 20/50 and 5 qts 10/40. You actually have 15/45 oil. Simple math.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
It can't hurt every so often.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
Thread Tools | |
Rate This Thread | |
