Banned
Doubt concerning rim width
Can I put 195/65-15 tires on a 15x7 rim ? Or are they too skinny ?
yes
Banned
Sorry, but you mean Yes, I can ?
I think Bill is saying yes to both questions.
They will fit the rim since they're 15" but yes, they are a tad skinny. 205-60 would be a better choice IMHO.
Scott '78 SC mit Sportomatic - Sold |
+1
too skinny Regards |
3.4 Bigger is better
The factory size for my 88 on the front 15x7 is 195/65-15's. They fit just fine on the seven's. I put 205/60-15's and they were better and are virtually the same height as the 195's.The rears are factory sized at 215/60-15. Can the tires ever be too wide
![]() I have changed to 17's due to limited tire choices on the 15's. Not much in 15" sizes anymore.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Banned
I'm moving from 16" back to 15". Despite limited tire choice I want a more "relaxed" ride.
I bought 15x7 rims all around, so now I can choose between 195/65 or 205/60 at the front. I'm thinking of the skinnier ones as they probably make the steering lighter while parking and a tad more "agile"... At the rear I'll go for 215/60. |
A more relaxed ride is what I was after too when I went back to 15's also.
I think you've got a good plan going skinnier if that is what you want the car to 'feel' like. I once went from a 205-60 on a 6x15 to a 195-60 on a 6.5x15 and the steering feel was great. This was on a '67 912 by the way. Let us know how it works out.
yes, 195/65 fits on a 7" rim
here's a pic ![]() Is it too skinny? depends on what else is on the car and how you use it and what you expect from it
Prebordo,
I have 7X15 rims on all corners of my 73T. One pair came with a nearly new set of 195/65 tires which I mounted on the front, the other pair have 205/60's and are on the rear. It's very difficult to tell the difference, visually, unless you look for it and the speedo is still nearly right-on in accuracy. You should have no problems with that combination, but be careful if you choose the 215/60 for the rear--you may have clearance issues with the fender, depending on your ride height.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
My car has 25 y/o 185/70-15 pirrellis on it now, that was the size in the 70's. I like the look of the skinnier tires especially on older 911s I think it helps distinguish its age. I am looking at new tires now and will have to go to the 195/65 just because no one makes the 185/70 anymore.
75 911s 86 951 sold to make room for baby seat 09 335i 6MT NVH |
Banned
I just bought a set of 15x7 cookies and was concerned that 195 at the front was too skinny.
But yesterday I read in Peter Morgan's 944 book that early ones had 185 tires on 7" fuchs ! At the back, 215's will be ok as I have flares. |
