Push Buttons to open door from inside?
Hi All,
Is it true that 69 911's had a push button on the arm rest to open the doors? Any pictures? Anyone have an exploded diagram of the mechanism? Thanks, Adam
_____________________ '73 RSR Interpretation ---------------------------------- |
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-24-2009 at 09:44 PM.. |
300hp 1800lbs is the goal
Found this while looking for something else.....
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Wow... man oh man were exploded diagrams crap in the late 60's.. It looks liek a doodle haha
So it appears that the pushrods rotates a horn to open the door. Do you think it would be possible to adapt this sort of arm rest to the mechanism from the SC/3.2 Carrera models? I understand that the direction of movement is different. Could some one please post pictures of the difference in door trim for 65 - 69? Thanks,
I'll try and find my inner door handles later today... their in a box somewhere.... I was planning on just putting a simple flat panel on the door and working up a simple pull handle. I haven't really looked at the parts, but yes they may work in reverse.
Just in case anyone ever reads this thread, here are pics of what i think are the right doors. Someone correct me if I'm wrong.
And if someone could tell me how to get the 65-68 door handles to work with my 86 doors I'll be very happy ![]() 65-68 ![]() 69-
I have a early Targa door up in the garage with the door pnl off, will take a pic of the mechinisam and post it later this evening.
I like the push button on my early cars better than the tab / lever on the 71, the button falls into place when I reach for it, on the 71 I usually reach across with my right hand to open it. That is a thought to swap the stuff from a pair of 68 doors I have?? Regards |
any luck on the pictures?
bump for the pictures?
I'm sure there is a piece missing here, but here's the pics...
![]() ![]() ![]() The doors themselves are buried, so I can't get access to them...The car was in boxes when I got it, but I believe there is a round section that the lever pushes on, on the bottom.... I assume the later pull handles attach to the top of the circle and pull it forward..
Ah.. i see now... thanks for the post...
Can anybody confirm about the round section? Also, is it true is that the button is recessed in the 68 handles?
