vincer77's Avatar
Smith's book is wonderful but quite old (1950s?) -- doubt if it is in print but get your library to use inter-library loan
there must be some more recent book on all this but have not seen one that is minimally technical.
Still available on amazon. There are more recent books that are pretty good, but they become too technical for the everyman.
Gordon Blair, Design and Simulation of Four Stroke Engines
DE Winterbone, Theory of Engine Manifold Design
Cheers,
Vince -1997 993 Cabriolet, Arena Red, M030, Bilstein HDs, RSR exhaust, HIDs
"'Safe?' said Mr. Beaver...'Who said anything about safe? 'Course he isn't safe. but he's good. He's the King, I tell you.'"
Old 10-28-2009, 04:06 PM
psalt - sorry, but what is VE?
Hello David,
Volumetric Efficiency. An expression of how much of the cylinder is filled or the ratio of actual volume to ideal volume as a percentage of displacement. Most N/A engines are below 90%, because of restriction like the intake valves, ports, manifolds, etc. Supercharged engines can exceed 100% VE, the more mixture you can put into the cylinder, the more power you can make. VE is low when there is vacuum in the manifold and VE is highest at the torque peak under WOT. This is when cylinder pressure is highest and the probability of detonation is highest, requiring the knee in most ignition advance curves. Resonant intake tuning (velocity stacks) is all about raising the VE above what it would "normally" be at a specific rpm.
Paul
Old 10-28-2009, 04:09 PM
Some good discussion of inlet dynamics (and simulation) can be found here, with graphs showing effect of inlet dymanics at various engine speeds
It also raises an intersting (and rarely discussed) point - residual exhaust gas in the cylinder charge. It's all well and good to get VE above 100%, but you also need to ensure that you've eliminated as much of the exhaust gas as possible (through valve overlap and exhaust dynamics) They go hand in hand.
See page 2&3 of the PDF
http://www.bosch-motorsport.de/content/downloads/Software/lapsimengine.pdf
Old 10-28-2009, 07:43 PM
