-   -   What color for Wheel wells after color change (http://forums.pelicanparts.com/porsche-911-technical-forum/507564-what-color-wheel-wells-after-color-change.html)
Brad w 10-28-2009 12:57 PM
The PO changed colors on the car several years back and I like the blue. I don't understand why they did not paint the wheel wells. The painted everything else. What color should I paint, Black or Blue?
Thanks. http://forums.pelicanparts.com/uploa...1256759854.jpg
nineball 10-28-2009 12:59 PM
black. it will stand up to dirt better than the blue will.
Brad w 10-28-2009 01:00 PM
http://forums.pelicanparts.com/uploa...1256759983.jpg
http://forums.pelicanparts.com/uploa...1256759999.jpg
A few more pics
Dixie 10-28-2009 02:42 PM
I suggest blue. The factory painted the wheel wells the same color as the outside.
Roc Doc 10-28-2009 02:49 PM
If it's a driver I agree with the above.
As you can see from the pics, I did a color change and my painter did a great job painting the wheel wells to match the Minerva Blue of the body. Now look at the last picture and tell me what color they are. :D
http://forums.pelicanparts.com/uploa...1256766541.jpg
http://forums.pelicanparts.com/uploa...1256766557.jpg
http://forums.pelicanparts.com/uploa...1256766566.jpg
euro911sc 10-28-2009 07:18 PM
Should have just left them dirty as hell and no one would know the difference ;)
-Michael
Canada Kev 10-28-2009 08:10 PM
Just get a rattle can mixed in that color, pressure wash the wheel well so it's clean, mask off your struts and spray it to mostly cover the red. It'll be dirty in no time.
rattlsnak 10-28-2009 08:11 PM
defintely black..
proffighter 10-29-2009 12:37 AM
BLACK of corse:D
http://forums.pelicanparts.com/uploa...1256801833.jpg
WPOZZZ 10-29-2009 01:48 AM
Blue, then a light undercoating just like the factory.
Vmarch 01-09-2010 10:35 PM
You wonder why the PO did not paint the wheel wells when the color was changed? Money!
It takes at least 2 to 3 hours to scrub and clean each wheel well to get the dirt and grime out. The easiest wheel well to do is the left rear. The front rear has AC, windshield washer lines and fuel filler drain hose as well as the evaporator for the AC, the windshield resevoir, fuel emissions cannister. You have to take all the crap out to clean and paint. The right front has the oil lines and the right rear has the oil tank.
after cleaning the wells then you need to prime them and finish coat, then return everything. Figure its at least a $3,000 job or more if done right. I learned the hard way, bought a color changed car and redid my wheel wells and luggage compartment after removing the fuel tank.
sc_rufctr 01-09-2010 10:39 PM
Why not slop some POR15 over the clean paint and call it a day?
Porsche-O-Phile 01-10-2010 02:28 AM
For best adhesion POR-15 should be applied to bare metal, although they do make a primer that can serve as a bridge between existing surfaces/paints and the POR-15 epoxy stuff.
FWIW your suggestion is most likely the way I'm going to go with my own car (black wheel wells) albeit with a topcoat to prevent any UV damage long-term (also black).
stlrj 01-10-2010 04:54 AM
I don't know why, but whenever I see the same color in the wheel well, it reminds me of over-spray from a cheap paint job. Better not to attract attention to that area as much as possible.
Cheers,
Joe
yellowperil 01-10-2010 06:14 AM
If your wheel wells are in good condition and undercoat is good, then my vote is for body color blue; more a factory look I think.
yellowperil 01-10-2010 06:16 AM
PS: For sure put enough paint on so it doesn't look like overspray.
kodioneill 01-10-2010 06:29 AM
I'm not sure but I think the factory used black after the 76 models or so correct me if I'm wrong. my 74 wells are the same as the paint job. my 82 and 85 are black and do not appear to have ever been painted just a very hard black thin undercoat.
Griffinroydonal 01-10-2010 06:34 AM
Color
I vote for black undercoating
yellowperil 01-10-2010 06:45 AM
Maybe they're all different from the factory, but my original paint iris blue carrera is body color over undercoat.
tharbert 01-10-2010 07:35 AM
DD = Black
Concourse = Blue
With black, the occasional power wash and a couple squirts of protectorant looks great. If you paint it body color, you'll want to detail it back to that fresh new look. You could always just hit a few puddles to replace that road grime patina over the red.
roger's 2937 01-10-2010 08:32 AM
My '89 came with black undercoating in the fender wells and I just finished cleaning them up and re-undercoating.
http://forums.pelicanparts.com/uploa...1263141090.jpg
http://forums.pelicanparts.com/uploa...1263141130.jpg
al lkosmal 01-10-2010 08:44 AM
Wurth
Wurth high build undercoat (black). Not necessarily the correct color for your year, but my preference. Turns out nice.
http://forums.pelicanparts.com/uploa...1263141741.jpg
http://forums.pelicanparts.com/uploa...1263141803.jpg
http://forums.pelicanparts.com/uploa...1263141838.jpg
canamfan 01-10-2010 10:05 AM
Body colour in the same quality as the rest of the car with attention to a factory "wax" type coating. In Canada, when I see "black" undercoating it's like they're trying to hide major imperfections,overspray, rust etc., as well as not wanting to spend the needed money to "finish" the paint job or hide the fact it had a colour change. Some say the black looks better because it doesn't show all the dirt? You might as well spray some on the rest of the car to hide dirt?? I find keeping the (properly painted and coateded) body coloured wheel wells clean very easy because dirt doesn't stick to it like black undercoating. Just my opinion.
