Brad w's Avatar
What color for Wheel wells after color change
The PO changed colors on the car several years back and I like the blue. I don't understand why they did not paint the wheel wells. The painted everything else. What color should I paint, Black or Blue?
Thanks.
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 10-28-2009, 12:57 PM
nineball's Avatar
black. it will stand up to dirt better than the blue will.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 10-28-2009, 12:59 PM
Brad w's Avatar
A few more pics
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 10-28-2009, 01:00 PM
Southern Class & Sass
Dixie's Avatar
I suggest blue. The factory painted the wheel wells the same color as the outside.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-28-2009, 02:42 PM
Roc Doc's Avatar
If it's a driver I agree with the above.
As you can see from the pics, I did a color change and my painter did a great job painting the wheel wells to match the Minerva Blue of the body. Now look at the last picture and tell me what color they are.
1976 911S Targa, Carrera bodywork, 3.2l engine.
Old 10-28-2009, 02:49 PM
Less brakes, more gas!
euro911sc's Avatar
Should have just left them dirty as hell and no one would know the difference
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-28-2009, 07:18 PM
Formerly known as Syzygy
Canada Kev's Avatar
Just get a rattle can mixed in that color, pressure wash the wheel well so it's clean, mask off your struts and spray it to mostly cover the red. It'll be dirty in no time.
Kevin
Old 10-28-2009, 08:10 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
defintely black..
Old 10-28-2009, 08:11 PM
proffighter's Avatar
BLACK of corse
Roland
930 Turbo '81 Too many modifications to list
Old 10-29-2009, 12:37 AM
WPOZZZ's Avatar
Blue, then a light undercoating just like the factory.
Old 10-29-2009, 01:48 AM
You wonder why the PO did not paint the wheel wells when the color was changed? Money!
It takes at least 2 to 3 hours to scrub and clean each wheel well to get the dirt and grime out. The easiest wheel well to do is the left rear. The front rear has AC, windshield washer lines and fuel filler drain hose as well as the evaporator for the AC, the windshield resevoir, fuel emissions cannister. You have to take all the crap out to clean and paint. The right front has the oil lines and the right rear has the oil tank.
after cleaning the wells then you need to prime them and finish coat, then return everything. Figure its at least a $3,000 job or more if done right. I learned the hard way, bought a color changed car and redid my wheel wells and luggage compartment after removing the fuel tank.
Old 01-09-2010, 10:35 PM
Almost Banned Once
sc_rufctr's Avatar
Why not slop some POR15 over the clean paint and call it a day?
- Peter
Old 01-09-2010, 10:39 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
For best adhesion POR-15 should be applied to bare metal, although they do make a primer that can serve as a bridge between existing surfaces/paints and the POR-15 epoxy stuff.
FWIW your suggestion is most likely the way I'm going to go with my own car (black wheel wells) albeit with a topcoat to prevent any UV damage long-term (also black).
Black Cars Matter
Old 01-10-2010, 02:28 AM
I don't know why, but whenever I see the same color in the wheel well, it reminds me of over-spray from a cheap paint job. Better not to attract attention to that area as much as possible.
Cheers,
Joe
Old 01-10-2010, 04:54 AM
If your wheel wells are in good condition and undercoat is good, then my vote is for body color blue; more a factory look I think.
Old 01-10-2010, 06:14 AM
PS: For sure put enough paint on so it doesn't look like overspray.
Old 01-10-2010, 06:16 AM
kodioneill's Avatar
I'm not sure but I think the factory used black after the 76 models or so correct me if I'm wrong. my 74 wells are the same as the paint job. my 82 and 85 are black and do not appear to have ever been painted just a very hard black thin undercoat.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-10-2010, 06:29 AM
Griffinroydonal's Avatar
Color
I vote for black undercoating
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 01-10-2010, 06:34 AM
Maybe they're all different from the factory, but my original paint iris blue carrera is body color over undercoat.
Old 01-10-2010, 06:45 AM
tharbert's Avatar
DD = Black
Concourse = Blue
With black, the occasional power wash and a couple squirts of protectorant looks great. If you paint it body color, you'll want to detail it back to that fresh new look. You could always just hit a few puddles to replace that road grime patina over the red.
Old 01-10-2010, 07:35 AM
