Mitch Leland's Avatar
"84' vs "85" a/c dash...
Is the "85" dash (top panel) with the larger A/C vents interchangeable with an "84" car? I'm looking for a donor dash so I can recover the dash for my "84", other than the originality factor I understand the later dash gives better A/C air distribution.
Are they interchangeable, and if you were looking for a "donor dash" would you consider making this change?
Thanks...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 10-30-2009, 12:45 PM
carreraken's Avatar
My '85 has the small vents...
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 10-30-2009, 12:47 PM
A/C Vents...
Ok, when did the A/C vents get bigger.... "86"?
Mitch Leland
Old 10-30-2009, 01:00 PM
my '86 has the bigger vents, but I don't know if they're interchangable
Old 10-30-2009, 01:05 PM
NewfieMZ3's Avatar
to the best of my knowledge the 84 and 85 are interchangeable, this is cover in Wayne's 101 projects.
1984 911 Coupe
2007 Z4 M Coupe
2008 Cayman S
2004 M3-Alpine White(sold)
2002 M Roadster (sold)
Old 10-30-2009, 01:13 PM
MBAtarga's Avatar
In order to use the later dash (with the larger vents), you've got to do quite a bit of modifications to the metal dash as well as change out the air duct work.
Mark
'83 SC Targa - since 5/5/2001
Old 10-30-2009, 02:12 PM
1986 was the year Porsche switched to the big vents.
1986 Targa
1968 MGB (2)
Old 10-30-2009, 06:42 PM
Detached Member
Hugh R's Avatar
Friend of mine who used to post here did an SC to 86 dash, it was a lot of work.
Hugh
Old 10-30-2009, 06:52 PM
Looks like it's more work than I want to get into... Too bad, we can get good cold air with the upgrades, but the other part of the equation is getting the air distributed into the cabin. I know you can get some of the after market vents, but I'm not keen on them. Life is full of priorities...
Thanks for every ones input...
Mitch Leland
Old 10-30-2009, 09:08 PM
