-   -   80 SC Distributor Orientation (http://forums.pelicanparts.com/porsche-911-technical-forum/508051-80-sc-distributor-orientation.html)
K Sykes 10-31-2009 04:39 AM
I need to verify my distributor is oriented properly and the sparkplug wires are in the right order. There are several good posts on how to do that (firing order, CCW rotation etc.) and I have what I need except for one thing. All the posts talk about orienting the rotor at #1 TDC to a notch in the distributor. Is this notch the same as the orientation notch for the distributor cap? I am talking about the roughly 1/2" long notch that aligns the cap to the distributor body.
In other words is #1 wire on the cap the wire that is at this notch?
Kinsley
Walter_Middie 10-31-2009 06:27 AM
No - the notch in the distributor is about as wide a pencil line on a piece of paper. I'll look for a picture and post it.
Walter_Middie 10-31-2009 06:33 AM
This shows a rev limiter rotor, but I think you get the idea.http://forums.pelicanparts.com/uploa...1256995998.jpg
K Sykes 10-31-2009 07:12 AM
Perfect. That helps a lot.. and explains some of the timing challenges I have been having.
BTW, what year is your car?
Walter_Middie 10-31-2009 07:34 AM
I think the picture is from a 1975 with a 2.7 liter engine - same as mine, except my engine is a lot cleaner, and my engine tin is perfect.
K Sykes 10-31-2009 02:23 PM
That was it, runs like a champ now.
Kinsley
SteveinTO 11-01-2009 07:37 AM
This is what it should look like timed per factory specs at TDC #1. Mine is an '82.
http://forums.pelicanparts.com/uploa...1257089787.jpg
