80 SC Distributor Orientation
I need to verify my distributor is oriented properly and the sparkplug wires are in the right order. There are several good posts on how to do that (firing order, CCW rotation etc.) and I have what I need except for one thing. All the posts talk about orienting the rotor at #1 TDC to a notch in the distributor. Is this notch the same as the orientation notch for the distributor cap? I am talking about the roughly 1/2" long notch that aligns the cap to the distributor body.
In other words is #1 wire on the cap the wire that is at this notch?
Kinsley
Old 10-31-2009, 04:39 AM
No - the notch in the distributor is about as wide a pencil line on a piece of paper. I'll look for a picture and post it.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 10-31-2009, 06:27 AM
This shows a rev limiter rotor, but I think you get the idea.
Rex
Old 10-31-2009, 06:33 AM
Perfect. That helps a lot.. and explains some of the timing challenges I have been having.
BTW, what year is your car?
Old 10-31-2009, 07:12 AM
I think the picture is from a 1975 with a 2.7 liter engine - same as mine, except my engine is a lot cleaner, and my engine tin is perfect.
Rex
Old 10-31-2009, 07:34 AM
That was it, runs like a champ now.
Kinsley
Old 10-31-2009, 02:23 PM
SteveinTO's Avatar
This is what it should look like timed per factory specs at TDC #1. Mine is an '82.
Old 11-01-2009, 07:37 AM
