Push Buttons to open door from inside?
Hi All,
Is it true that 69 911's had a push button on the arm rest to open the doors?
Any pictures?
Anyone have an exploded diagram of the mechanism?
Thanks,
Adam
_____________________
'73 RSR Interpretation
Old 10-24-2009, 09:09 PM
HarryD's Avatar
Originally Posted by StayGold808 View Post
Hi All,
Any pictures?
Thanks,
Adam
All '65 to '68's had a interior push button. You can check the PET to see the details here: http://www.porsche.com/all/media/pdf/originalparts/en/E_911-1_KATALOG.pdf . Look in the Body section under "Interior Lining" Page 387. In '69 they went to the internal pull in the arm rest.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-24-2009, 09:42 PM
300hp 1800lbs is the goal
pksystems's Avatar
Found this while looking for something else.....
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 10-24-2009, 11:35 PM
Wow... man oh man were exploded diagrams crap in the late 60's.. It looks liek a doodle haha
So it appears that the pushrods rotates a horn to open the door. Do you think it would be possible to adapt this sort of arm rest to the mechanism from the SC/3.2 Carrera models?
I understand that the direction of movement is different.
Could some one please post pictures of the difference in door trim for 65 - 69?
Thanks,
Old 10-25-2009, 12:24 AM
pksystems's Avatar
I'll try and find my inner door handles later today... their in a box somewhere.... I was planning on just putting a simple flat panel on the door and working up a simple pull handle. I haven't really looked at the parts, but yes they may work in reverse.
Old 10-25-2009, 01:12 AM
Just in case anyone ever reads this thread, here are pics of what i think are the right doors. Someone correct me if I'm wrong.
And if someone could tell me how to get the 65-68 door handles to work with my 86 doors I'll be very happy
65-68
69-
Old 10-25-2009, 06:41 AM
I have a early Targa door up in the garage with the door pnl off, will take a pic of the mechinisam and post it later this evening.
I like the push button on my early cars better than the tab / lever on the 71, the button falls into place when I reach for it, on the 71 I usually reach across with my right hand to open it. That is a thought to swap the stuff from a pair of 68 doors I have??
Regards
Old 10-25-2009, 08:39 AM
any luck on the pictures?
Old 10-27-2009, 06:18 PM
bump for the pictures?
Old 11-02-2009, 01:16 AM
pksystems's Avatar
I'm sure there is a piece missing here, but here's the pics...
The doors themselves are buried, so I can't get access to them...The car was in boxes when I got it, but I believe there is a round section that the lever pushes on, on the bottom.... I assume the later pull handles attach to the top of the circle and pull it forward..
Old 11-02-2009, 03:00 PM
Ah.. i see now... thanks for the post...
Can anybody confirm about the round section?
Also, is it true is that the button is recessed in the 68 handles?
Old 11-02-2009, 03:53 PM
