72' 911S
C'mon....take a guess.
Finally got the header assemblies off the cylinders last night. I thought I would have some fun with this, because at this point all I can do is laugh.
So here's the big question - How many miles would you guess are on these Headers? The worst Exhaust Valves: ![]() ![]() ![]() ![]() And now the Tops: ![]() ![]() ![]() ![]() ![]() ![]() Let the games begin! |
Transplanted User
that kind of buildup can happen fast. I got my money on 1200 miles. The gaskets are too fresh
Matty K. - 82 SC Targa - SCWDP member #0052 "Racing - the sport that requires more than one ball to participate" |
Detached Member
Yeah, I'm thinking not too many miles either. First pic, did you burn off a valve stem?
Hugh |
Evolved
I'm going with, less than 10 miles.
Don't fear the reaper. |
72' 911S
Hugh - I have no idea what the white build up is on the valve although the valve itself does seem to be in tact. I will post actual miles tomorrow.
72' 911S
And the actual number is......8 miles!
I had a bad experience with a local builder here. I gave him almost 2 years to complete an engine rebuild and finally just had to go repossess my own car. He told me there were just a few things that needed to be done in order to get it running. Well I could never get it timed correctly, or even tune the carbs correctly. Then i found out the heads had no work done on them at all, none of the machining I requested. So I started tearing things apart. I hope the internals are good, pistons, rings, cylinders, crank; and that all I have to do here is a top end. We'll see.... |
user & abuser
sorry to hear that, its insane what some of these shops try and pull
vini vidi vici |
There are people that do great work in the Chicago area, If you need some recomendations PM me. I will put a plug in for my good freind Wally at Werner machine for your head work.
30 Year ASE Master Certified Technician 1986 911 |
Make Bruins Great Again
Who is this fine establishment that wasted 2 years of your Porsche life?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
This is why all my stuff is being sent out of state.
Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car |
