Ducktail deck fitting
I'm having a slight problem with getting my ducktail to snug down. I can get it to close but the latching mechanism isn't behaving. I can only shorten is so much and it won't grab the post. And when I adjust it to the point that it will grab the post the lid sits to "open". I guess what I'm trying to say is I can't get my deck lid to close all the way tight.
Any suggestions?
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 11-03-2009, 08:19 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I cheated on mine.....I took off the latch mechanism and have a strong magnet that keeps the lid closed. Works great for me
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 11-04-2009, 03:28 AM
TR TR is offline
TR's Avatar
deck lid latch line up problem
Mine had several washers under the front part of the hinge which tilted it back a bit, that was the only way it would sit "right", and close perfectly.
I later took it off and put back the original deck lid so it no longer is a problem. See if that works!
cheers
terry
Old 11-04-2009, 04:33 AM
Dixie Region R Gruppe
w21055's Avatar
Any suggestions?
Check to see if the rubber gasket is holding it up. If you can remove it, take it off and then shut it and see if it closes down all the way. Before I backdated mine I had the exact same problem and the main reason was the rubber gasket was not seated all the way down.
Phillip
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 11-04-2009, 04:43 AM
