-   -   Using anti-seize or synthetic grease on brake caliper bore to prevent rust (http://forums.pelicanparts.com/porsche-911-technical-forum/508935-using-anti-seize-synthetic-grease-brake-caliper-bore-prevent-rust.html)
oly 11-04-2009 03:12 PM
How many people do this?
My DE instructor, who is also a mechanic recommended it. Specifically, he puts copper anti-seize on the bore surface that is behind the dust seal and on the non pressure side of the o-ring. This seems like a very good idea because the dust seals don't survive very long in a track environment.
Also it seems like an even better idea would be to use nickel anti-seize or ceramic brake caliper synthetic grease instead. Permatext information:
copper anti-seize to 1800F
nickel anti-seize to 2400F
synthetic brake grease to 2800F
What does everybody think?
McLovin 11-04-2009 03:19 PM
since its just on the non pressure side of the oring, and behind the dust seal, it couldn't hurt to do that.
James Brown 11-04-2009 03:21 PM
As long as it's not on the wet side of the piston I don't think Therese any problem as long as this is a track car (brakes rebuilt every season). But for everyday drivers, not nessary.
Bill Verburg 11-04-2009 03:40 PM
The piston bores should be lubed w/ Unisilikon TK 44 N paste
the pad seating and pad sliding points should be lubed w/Optimoly HT which is a Cu based paste
the Permatex products noted are probably equivalent
oly 11-04-2009 04:49 PM
Bill,
Does "The piston bores should be lubed w/ Unisilikon TK 44 N paste" mean behind the dust seal and on the non pressure side of the o-ring? Or the whole bore?
What is Unisilikon TK 44 N paste and where do you buy it?
And where do you buy Optimoly HT?
Bill Verburg 11-05-2009 04:32 AM
Originally Posted by oly (Post 4992277)
Bill,
Yes, use Unisilikon anywhere under the outer seals and a dab of HT along the sliding edges of the pads.
Both are available through the Porsche parts systems but are considered hazardous materials. Some places won't ship them as a result.
Unisilikon is Porsche part # 000.043.117.00 for a 50 g tube
Optimoly HT is Porsche part # 000.043.004.00 for a 90 g tube
I have used Permatex for the Cu based high heat lube also Optimoly and Plastilube
Gogar 11-05-2009 05:32 AM
PP sells plastilube; I used it last time and it was good times, man. Good times.:p
oly 11-05-2009 05:30 PM
Okay, thanks for the posts everybody!
