1985 Carrera Coupe
How many people do this?
My DE instructor, who is also a mechanic recommended it. Specifically, he puts copper anti-seize on the bore surface that is behind the dust seal and on the non pressure side of the o-ring. This seems like a very good idea because the dust seals don't survive very long in a track environment. Also it seems like an even better idea would be to use nickel anti-seize or ceramic brake caliper synthetic grease instead. Permatext information: copper anti-seize to 1800F nickel anti-seize to 2400F synthetic brake grease to 2800F What does everybody think?
Art |
Checked out
since its just on the non pressure side of the oring, and behind the dust seal, it couldn't hurt to do that.
Senior Advisor
As long as it's not on the wet side of the piston I don't think Therese any problem as long as this is a track car (brakes rebuilt every season). But for everyday drivers, not nessary.
08 Cayenne Turbo |
the pad seating and pad sliding points should be lubed w/Optimoly HT which is a Cu based paste the Permatex products noted are probably equivalent
1985 Carrera Coupe
Bill,
Does "The piston bores should be lubed w/ Unisilikon TK 44 N paste" mean behind the dust seal and on the non pressure side of the o-ring? Or the whole bore? What is Unisilikon TK 44 N paste and where do you buy it? And where do you buy Optimoly HT?
Art |
Both are available through the Porsche parts systems but are considered hazardous materials. Some places won't ship them as a result. Unisilikon is Porsche part # 000.043.117.00 for a 50 g tube Optimoly HT is Porsche part # 000.043.004.00 for a 90 g tube I have used Permatex for the Cu based high heat lube also Optimoly and Plastilube
Band.
PP sells plastilube; I used it last time and it was good times, man. Good times.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
1985 Carrera Coupe
Okay, thanks for the posts everybody!
Art |
