-   -   Problem installing Tarett Sway bar (http://forums.pelicanparts.com/porsche-911-technical-forum/508955-problem-installing-tarett-sway-bar.html)
torresmd 11-04-2009 05:10 PM
I am in the process of installing a rear Tarett sway bar in my 1986 Turbo. I fit one side, no problems, but when I try to mount the passenger side, it stops about 1/4 to 1/2 in shy of the stock mount. I realize that the bar is hitting the tranny mount. Has anyone had this issue? Am I doing something wrong?
Chuck Moreland 11-04-2009 05:14 PM
On the turbo you typically have to space down the bearing blocks for clearance. Use some flat washers, both sides.
torresmd 11-04-2009 05:16 PM
Thanks Chuck!! I will do that.
