spsfiend's Avatar
Are H4s with Chrome Rings Paintable?
I don't think I like the look of Chrome on my H4s... Can they be painted if I take them to a body shop?
Thanks!
Old 11-02-2009, 10:36 AM
rw7810's Avatar
The chrome would have to be stripped off. You probably are better off buying some primered ones and having them painted. Keep the chrome ones for when you change your mind.
Robert Williams
70' 911T
Old 11-02-2009, 10:51 AM
OttawaDave's Avatar
I'd grab a set of primered trim rings that mount over top of the chrome assembly. You'll need a pair of special set screws to mount them (all available from our host).
Old 11-02-2009, 11:28 AM
Can't paint chrome. At least not successfully, and not without roughing it up enough that you might just as well remove it.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-02-2009, 01:13 PM
Painted rings will fit over the chrome rings.
Old 11-02-2009, 01:37 PM
dtw dtw is offline
GAFB
Just bead-blast the chrome off the trim rings.
I like the painted trim ring covers better, though.
Several BMWs
Old 11-02-2009, 02:09 PM
spsfiend's Avatar
Thanks for the info gang! Will look into the paintable rings that fit over. That wold be ideal!
Old 11-02-2009, 02:26 PM
spsfiend's Avatar
Found the Ring Part #: 911-631-141-00-M260
Can someone confirm which screw I need? I see an "Outer" and an "Inner" screw. Do I just need the outer screw or both?
Thanks!
Gerry
Old 11-02-2009, 02:30 PM
OttawaDave's Avatar
There are a lot of old posts on this - but you'll need two screws, the first holds the assembly to the fender, the second screws into the first to hold the trim ring on.
Old 11-02-2009, 02:49 PM
Arrow
I'll trade you a set of paintable rings all-ready stripped and primed. I have the h4 (under) rings not the covers.
These have been stripped down (brass) and have a light coat of primer on them, I would primer them better for shipping they are a but scuffed from the box they were in ,easy fix. If you want a coat of black on em I can spray them, screws are intact.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 11-02-2009, 03:48 PM
He can't trade the chrome rings he needs those under his trim rings
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-02-2009, 04:37 PM
the rings in the pic above replace the chrome rings - note the adjustment screws
_____________________
'73 RSR Interpretation
Old 11-02-2009, 10:06 PM
i'm looking for a pair of chrome H4 rings by the way. If you are interested in selling let me know
Old 11-05-2009, 04:48 PM
Alii&Maui
Jesset100's Avatar
I painted mine.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 11-05-2009, 06:24 PM
