I believe there is an article on this site that says remove plugs before doing valve adjustment. What to do!
OK. I guess the instructor at the Porsche school was wrong. What did he know, being factory trained and all? Pardon me (and all the other experienced techs).
The Cap'n |
Because the seal on each plug is a crush washer, it's supposed to be a one-time use item. I haven't seen replacement washers in years, although they're probably still available somewhere. You used to be able to get them in various thicknesses, for those who indexed their plugs. Dunno if you can still get those, either.
The Cap'n |
Off topic but for plugs, I heard that what colour they are doesn't truly depict how rich/lean the car is running?
I can't fathom how combustion and the associated colouration that comes with it would be any different to a "normal" engine... |
Lead is a big factor in plug color. The absence of lead in modern fuels has made plug reading pretty much a thing of the past.
The Cap'n |
Good thing I've a AFR wideband kit in the mail then!
Thanks cap'n! |
Valve adjustment
If you really want to use the crankshaft nut to turn the engine while doing a valve adjustment, just drop the muffler. With it out of the way there will be plenty of room!
1. Rotate crank pulley with wrench or equivalent 2. Remote starter switch (or disable ignition circuit and use the ign. switch to crank) 3. Roll vehicle forward while in gear (parking brake OFF) Your choice to remove spark plugs or other engine pieces with the usual caveats about debris around the plugs. Sherwood |
| All times are GMT -8. The time now is 10:26 PM. |
