Rodek
How long do you warm it up?
How long do you let your 911 warm up before driving it?
1978 911 SC |
I don't. I drive it to warm it up. Keeping at 4000 rpm or so until I get to he first hash mark on my temp gauge give or take. When everything feels and smells right, I have at it.
Banned
I start it up, and if it has oil pressure, I drive it immediately. I don't go over 3500 until the oil temp gets past the first white hash mark on the gauge.
I don't. Its customary to drive off almost immediately. Maybe just a few seconds to let the fuel system stabilize and the whatever gadgets and gizmos on your particular model to adjust. It will come up to temperature quicker that way, and excessive idling never did any engine any good. Just refrain from high rpm/full load until up to normal operating temps.
I sort of rely on the throttle on my '73. I nurse it along after getting it out of the garage with the throttle at about 2K rpm and sense that everything is ok when I can put the throttle on the floor and it maintains engine rpms without a stall.
Tom |
Sadly, redlining in third would get me pulled over. Why can't I have fun?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Rodek
I let mine idle for a couple of minutes before driving. I was curious as to what others were doing.
1978 911 SC |
Drive away slow, only 3/8 throttle, shift at 3,000 rpms until ~160 degree oil temps.
1987 928 S4 - Black 2014 C4s 991 - Agate Grey 2014 Cayenne - Mahogany metallic |
Fastest Hunk of Junk
This is the advice I have always been given, and have heard the same about BMW M engines. Keep revs low and throttle below half until warm, but idling isn't helping anything.
-Brent |
Idle for a minute, then drive away moderately, keeping it under 3K until the oil temp gets close to normal (first mark) . Then, let loose.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) |
911 Besitzer
Wait to make sure the garage closes all the way, then go. I get a couple of drags in the first 1-2 minutes, then she's good to go. As others said, I start slowly, let her warm up while I drive safely through the neighborhood, then cut loose.
1984 911 Targa 2008 BMW 128i 2007 Jeep Liberty |
I find my carbs can be a bit more cranky depending the air temp. In the summer its start and go. In the winter it takes a bit more patience.
1976 911S MidYear Fever is alive and well. Last edited by Uncle Enzo; 09-09-2014 at 08:56 PM.. |
I warm mine up as long as I can considering the situation. I never load or rev cold engines. honestly, it's respect of your engine. imho cheers, g
Read your owner's manual. Don't do that. Drive it gently, immediately... Last edited by tcar; 09-09-2014 at 08:57 PM.. |
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Start 'er up. 1,600 revs for about 60 seconds. Drive off and don't go over 3,000 revs until the oil temp gauge is in the fully warmed up stage (single line) then I drive it in a lively manner but not going above 5,500 or 6,000.
Like everybody says, "no warm-up". I drive at not much more than 3000 RPM until the oil temperature gets well out of the white zone. I was told early on, in the 60's, it is bad for any engine. I never did it, especially even when staring on freezing winter days. I did the same with all my cars and they seem to reward me with long engine life.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
ROW '78 911 Targa
Start it, back it up and wait for garage door to close, then drive it under 3200 rpms until it hits the first oil temp line. (Warmed up)
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 09-10-2014 at 08:25 AM.. |
really?? sounds wrong on like 3 levels. first off, metals expand at different rates when heated. that was the reasoning behind divilar originally. this is an sc 3 liter that was being discussed. let it warm up. especially cis. your thermotyme won't shut off enrichment and you'll probably foul plugs. imho cheers, geoff
Long enough to put my seat belt on and make sure oil pressure's normal. 10 seconds. Then I follow the instructions in the manual...
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
