I'm a Registered User!
'76 911S Backfire + Die
Hey all,
I have a 1976 911S that sat for about a year. It was started about every month and sometimes driven for short drives.
However, on the last drive it backfired and died. I cannot restart it. I have not tested anything yet, what should I look for first?
Obviously I should check for spark and gas, is there anything that would sound like it broke?
Thanks,
Greg
1983 280ZX N/A 2-Seater T-Top red w/ black + silver interior
1986 Volvo 740 GLE - RallyCross Car
1976 Porsche 911S Euro-spec, Black on Black on Black
Old 11-08-2009, 03:28 PM
I have read this can be cause by the coil going out. I am going to be checking it with a multimeter later tonight, does anyone know the resistance specifications for the coil?
Old 11-08-2009, 04:36 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Not sure about the coil resistance.
76 is CIS right? It could be a blown air box. Do a search for blown air box or cracked air box. You'll see plenty of pictures and how to tell if that is what happened.
1981 SC ROW Coupe
Old 11-08-2009, 04:54 PM
Agree that blown air box, stuck pop-off valve (if you have one), or air leak from backfire is likely cause. Do check for spark first, however. If present, you likely have a massive air leak which prevents the car from running.
Question: When cold, does the car fire-up and immediately die or is there no firing at all in the engine?
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-08-2009, 05:41 PM
I'll check the air box as well tonight. I remember looking around right after it happened and not noticing anything wrong with the air box.
It does not start cold but it turns over nicely. Also, if I remember correctly, the gauges went kind of haywire prior to it's death if that gives any info.
Old 11-08-2009, 06:55 PM
Designer King
Paulporsche's Avatar
Check the points first.
Check all other electrical and ignition items.
Check for vac leaks.
Check the fuel injection incl the WUR and fuel & control pressures
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-08-2009, 08:05 PM
Checked out
McLovin's Avatar
your airbox is cracked, or something related has blown off, and you now have a massive vacuum leak that is preventing the car from starting.
Old 11-08-2009, 08:18 PM
Box is not broken. I will have to look for other vacuum leaks when there is light outside since my cellphone light is not cutting it at 1AM
I will also look at the other things suggested, thank you very much for ideas!
As for the coil's resistances...
Between terminals 1 and 15 the resistance was 3.7 ohms
Between terminals 4 and 15 the resistance was 8.7 kohms
According to below, between terminals 1 and 15 is pretty off. Is that a big enough difference to be causing this? I might try cleaning the connections tomorrow on the receiving end of the coil.
Originally Posted by dshepp806 View Post
As to Bentley data for coil resistance specs for primary and secondary windings:
Primary (terminals 1, 15): 0.4 - 0.7 ohms
Secondary (terminals 4, 15): 5.0 - 8.7 Kohms
(Bentley 280-9)
Will have to research the other items...
Best,
(from)
Factory Coil Output
Old 11-09-2009, 12:13 AM
Updates:
Checked the air box (wow it's clean in there!) and most of the hoses near that. They all seem great.
I changed the coil with one from my Datsun since their ohm readings were within spec. Tried to start it with no success but I did notice a gas smell from the exhaust so we're good on gas. I then decided to check into the coil's power a bit more. There is no electricity going to the coil!
Now I'm going to be searching about that. (Sorry, don't have a manual so I just gotta keep searching) Will let you all know what happens!
Old 11-09-2009, 11:44 AM
fastfredracing's Avatar
Check the air box a little more carefully, take off the cover , and the air cleaner, there are small flat head screws in the bottom , and after an air box explosion, these are commonly sticking up out of the plastic.
But I guess if you have no spark, you have to take care of that first .
No left turn un stoned
Old 11-09-2009, 11:50 AM
The box is fine, all of the screws look great and everything is solid up top. It is definitely not getting spark. I think it is points or CDI related.
EDIT:
It was the points! Tomorrow = checking dwell.
Thanks for all your help, it could have been anything so any clues or directions to take were very helpful.
Old 11-10-2009, 04:00 PM
