can constant trickle charging be bad?
Since I don't get my garage queen out as often as I would like I keep my 86 Carrera on a trickle charger all the time. I have a new Optima red top in the car. After the car sat for a couple of weeks my alternator went out - coincidence? I don't know the age of the alternator that went but it's at least 5 years old with perhaps 1000 miles per year. Thanks
I wouldn´t have thought so. The trickle charge is only a problem when you are not macthing the rate at which the battery is losing juice. To much or too little is bad for the battery especially too much. The alternator may have a broken coil or through the lack of use the bearings might be siezed.
If what you're talking about is truly a "trickle charger," yes, it will be bad for your battery. There's a difference between a trickle charger and a float charger; this came up on a thread just last week. A trickle charger is designed to slowly and gently take the battery to full charge, but it doesn't then shut off. A constant charge, no matter how "trickle-y" it is, will eventually kill a battery.
A float charger is also designed to fully charge a battery, but when it senses that full charge, it shuts off and only re-animates if the battery's charge drops. It can therefore be left on a battery full time. Many people improperly use the terms interchangeably, so you may in fact be talking about a float charger. But if you aren't, don't leave that thing on your battery once it's charged.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Stafan I presume that a trickle charger with a so called regulator is actually a float charger. I was of the understanding that the regulator will measure the charge loss of the battery and keep it level without overcharging. A trickle charger without the regulator should be removed when full?
That's my understanding. A true "trickle charger" should be used to charge and then be removed. Let me find the thread I was referring to above, and I'll post the link in a minute.
Here's what a poster a few days ago said to read for info re. the difference between trickle and float chargers:
Flot vs. Trickle Charger - ADVrider If you want to read more, do a search for "trickle chargers" and you'll see a thread a few lines down titled "tricke [sic[ chargers."
I would use a "Battery Tender" for your needs.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Banned
I believe more sophisticated trickle-chargers stop charging after awhile and don't need to be removed. They monitor the battery condition and start trickle charging again if and when needed.
I have a Ctek XS 3600 which I believe does that. |
+1. You can leave a "Battery Tender" hooked up all winter and have nothing but a perfect battery in the spring. I know for sure as I use one on my race car with Odyssey 925 battery.
Gary R. |
I have Ctek 7000 and it is one of the best battery charger/maintenance device. All you do is to plug in and forget about it. It does everything automatically.
1981 black 930 with full 1st gen Gemballa bumpers kit. RUF classic wheels. Modification include: Mode Inc. (Bob Holcombe) full bay intercooler, headers, turbo, and muffler. 360RWHP. |
That is a float charger not a trickle. As stated trickle chargers do not shut off on their own. I need to pick up a couple more so I did some searching. The best price I found was for the battery tender jr from amazon for just over $23. Order $25 worth of stuff and shipping is free. The link is below but you will have to remove one of the "A" from the beginning of the url. For some reason the word is banned on here. http://www.AAmazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S/ref=sr_1_1?ie=UTF8&s=automotive&qid=1258038093&sr=8-1
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. Last edited by nineball; 11-12-2009 at 07:05 AM.. |
Pre Registered
I've used this Schumacher 10/2 amp float charger almost continuously on one infrequently driven car with the same Optima red top for more than 10 years now with no issues or problems.
![]() Tim |
Rick 88 Cab |
I use several Battery Minders and they have a feature that desulphate the batteries for longer life. They work great - leave them plugged in and forget about it.
Battery Chargers by BatteryMINDers.com |
Sulfation.... From what I understand lead reacts with sulfuric acid and forms lead sulfate in the electrolyte when the battery discharges. If it sits too long (as short as 24 hours in some cases) it forms more stable crystals, harder to turn back into lead. Keeping the battery fully charged will prevent this.
I would be skeptical of any desulphation claim with out seeing what current level pulses are applied and seeing some test data.
Rick 88 Cab |
Maybe temperature dependent. If the trickle charger doesn't increase the temperature beyond specs. (evaporates electrolyte), I think it should be fine.
Sherwood |
http://www.batteryminders.com/batterycharger/press_room/batteryminder-desulfation-method-unique.pdf |
Rick 88 Cab |
I don't get your point, the patent isn't required to...
The cited reference number didn't patent a method to reverse sulfation i.e. x frequency, y current level, z period. Their "truly unique" U.S. Patented methods don't address how they “dissolve” the sulfate. Looks like a lot of hype not backed up by fact.
Rick 88 Cab |
