-   -   I thought I could fix my clock (http://forums.pelicanparts.com/porsche-911-technical-forum/511627-i-thought-i-could-fix-my-clock.html)
scotricker 11-17-2009 06:54 PM
I got another one for the car, but then I thought this would make a cool desk clock if i could make it go. Well, it still doesn't.
I opened it up and it all looks fine. I sprayed it out with contact cleaner and then got my compressor going and blasted all that cleaner out of it.
hooked it up to 12V and it just sits there and stares back at me.
heck-dang-it it doesn't go.
what should I do next?
snbush67 11-17-2009 07:03 PM
Put it in a box and forget about it.
LakeCleElum 11-17-2009 08:15 PM
Clock, sorry, I misunderstood........Movin' on
GaryR 11-17-2009 08:18 PM
Send it to N. Hollywood Speedo and have it converted to quartz and fixed!
JohnJL 11-17-2009 08:40 PM
What is your 12v source?
Evans, Marv 11-17-2009 09:15 PM
Don't know what kind/year of clock you have, but I fixed the clock for my car. It's the old type that rewinds periodically. There are contacts inside that I soldered together that act as a sort of fuse. Than I put a 3 amp fuse inline. It's been a long time, so I can't remember the particulars but you can probably dig up the info if you keep at it. Good luck.
c0metdot 11-17-2009 10:22 PM
Fixed mine.
New type.
Nothing to lose, so I cracked it open.
Heated up the soldering iron and remelted some paths on the PCB.
Not sure why, but it works fine now.
Pelican Technical Article: VDO Clock Repair
Pelican Technical Article: VDO Clock Repair...
T77911S 11-18-2009 05:08 AM
bad solder joints are a common fix. clean everything well and look at the solder joints. you are looking for little cracks, sometimes they look like a little circle around the joint or pin. also look for joints that are a different color, usually more dull than the rest. if you cant find anything, hit them with the iron anyway, you may get lucky.
consumer electronics seem to be more prone to this than other stuff, perhaps they are trying to save money and the solder is not as good.
sc_rufctr 11-18-2009 05:17 AM
I tried fixing mine... now I have a blanking plate in my dash. :confused:
T77911S 11-18-2009 05:25 AM
i may be wrong, but i think there is a switch in the AFM that opens when there is no air coming into the engine that shuts off the FP.
racer_X 11-18-2009 07:40 AM
The white hand on my clock doesn't move- is this the second hand or a "marking" hand?
http://forums.pelicanparts.com/uploa...1258558825.jpg
mholbrook38 11-18-2009 07:56 AM
The white hand is a marking hand. Kind of wonder how the motor is doing at 7000+ rpm, 120 in 4th gear and about 2 bar of oil pressure. ?????
crusty73 11-18-2009 07:59 AM
clock
Do a search. I repaired mine with a $1.79 capacitor from Radio Shack.
happy repairs..
T77911S 11-18-2009 09:46 AM
155 MPH? one hand and taking a picture? turbo?
racer_X 11-18-2009 09:50 AM
It's a bone stock stock 2.7 with photoshop installed.
:D
Paulporsche 11-18-2009 03:07 PM
racer_x,
Try bdriving down King's Highway @ that speed! ;)
T77911S 11-19-2009 04:31 AM
good job with the photo shop.
fredheiler 02-19-2012 05:48 AM
Contact Points in the 356 Clock
I fixed my clock, thanks in part to some good tips on this site. Someone pointed out that the earlier clock with a white plastic case can be opened up easily, which I did. Mine looked good inside (no blown fuse, no broken solder joint, no cruddy gears), but the rewind contact points looked burned and pitted (just like old ignition points). My points file was too big, but a super-hard tip from my Dremel operated by hand worked great.
I haven't seen bad contact points mentioned on this site, so I hope this helps other 356 owners.
By the way, the 356 clock is like a fine, old wind-up watch, except the mainspring is rewound every time the electrical contacts close (they presumably power a magnetic coil, which turns the mainspring a bit).
I tested my cleaned-up clock by setting in the trunk and connecting it to the battery with test wires and alligator clips. It ran well, and I was able to fine-tune the fast-slow adjustment before putting it back in the dash.
