-   -   Part Unknown (http://forums.pelicanparts.com/porsche-911-technical-forum/511843-part-unknown.html)
stormmaster 11-18-2009 10:10 PM
Part Unknown
When I removed the fender from the left side of my 87 Carrera there was an unknown (to me) part. It appears to be black ABS plastic. I know its not the washer bottle....It has two hoses going into it. It is empty, whatever it is. I am just curious as to what it is and is it required to be put back? I am thinking it is some sort of vapor recovery tank....but that is just a guess....any help or ideas?
HarryD 11-18-2009 11:30 PM
Ayup.. Vapor recovery tank.
Looks kinda like this?
http://forums.pelicanparts.com/uploads/newvapor.jpg
proffighter 11-19-2009 12:12 AM
It's an expansion tank for the fuel tank:
http://forums.pelicanparts.com/uploa...1258618320.gif
stormmaster 11-19-2009 12:24 AM
That is kinda what I thought....now for the second part of my question....does it need to be reinstalled? Is it just for those times when the tank is completely full?
proffighter 11-19-2009 12:29 AM
Technically it can be removed, it's to compensate thermal expansion of fuel without leaving any vapors out into air
P.S. You have to route breather hose outside of the trunk and I think it's a bit of a risk, because fuel vapors can easily start burning
stormmaster 11-19-2009 12:55 AM
thanks for all the help.....once i found out what it was i did a search
HarryD 11-19-2009 07:20 AM
You should leave your vapor recovery system intact and functioning. Gasoline fumes are toxic and need to be managed properly. I addition to the riisks to your body, the fumes may find their way to an ignition source and them you wil have a KFC (Kentucky Fried Car).
cdrik915 11-19-2009 07:40 AM
It's a sort of canister , isn't it ????
We've got the same under the right rear fender but it seems like a bottle.
