speakers
Hi all
Perhaps a simple question, but the speakers on my 88 911 Cabrio are blown out, and I am trying to figure out where to find original type (Blaupunkt) door speakers. The rear speakers I found new from Pelican using the Porsche part number, but cannot seem to find the large door speakers anywhere. I would like to use the original speaker grills so do not want to buy aftermarket speakers. Thanks in advance for your thoughts...
Andrew
71 250C
82 300D-T
82 300D-T
88 911 Cabriolet
Old 11-15-2009, 11:10 AM
geoz's Avatar
911 645 433 00 i think
cheers
hg
1988 911 Cabrio
Old 11-15-2009, 11:56 AM
I installed Blaupunkt GTx 542 speakers 170 watt in the front had to made 1/4 collars, cause they sit out just a bit, GTx 462 in the rear. I didn't want to alter the hole in the door panel. Original Blaupunkt Reno SQR 46 meets my needs, 88 Ce.
Old 11-15-2009, 09:43 PM
douglas bray's Avatar
Believe it or not I took mine to G.A.S. and had the guys from the T.V. show "Pimp My Ride" install the same Blau's as Dan. They wanted to install all kinds of extras and couldn't understand why I just wanted the stock covers. Rather than collars they "modified" the inner plastic holder.
Old 11-16-2009, 07:00 AM
Thanks for the thoughts. That is the correct part number, but is no longer available. Will purchase aftermarkets and modify them to fit the stock cover... thanks again.
Andrew
Old 11-19-2009, 08:09 AM
Had to through the memory banks, but this setup has treated me very well for the past 8 years. If Rod's not still around (hope he is) the part numbers or their replacements should still be available.
Speaker replacement
Also looks very stock, not cheesy at all. Just plain black grills on everything, and I used the original tweeter frames and covers.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 11-19-2009, 10:37 AM
wannabee wannabee
WIL84911's Avatar
sorry to hijack a bit here but can't seem to find many of those tweeters next to the window switch on an 84 Carrera. My Boston Acoustics were stolen between the towing company and the stupid Ferrari expert (long story). anyone know of good replacements?
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 11-20-2009, 10:25 AM
nineball's Avatar
check out partsexpress.com they always have a large selection of decent cheap speakers. look into the tang brand.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-20-2009, 10:41 AM
wannabee wannabee
WIL84911's Avatar
nineball, thanks!
Old 11-20-2009, 02:26 PM
Went with MB Quarts in my '88...not factory but great sound. needed a little modification though on the panels. Also added a nice 4 ch. amp bridged to 2 channels.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-20-2009, 04:14 PM
muck-raker
kidrock's Avatar
+1 on the MB Quartz in my '88 Cab as well. Great sound...and they're German!!!
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-20-2009, 05:41 PM
wannabee wannabee
WIL84911's Avatar
thanks.. will definitely look into MB Quartz. being a music lover I might also look into bridging a decent amp. so did you use the amp only for the door speakers?
Old 11-20-2009, 05:57 PM
nineball's Avatar
if you are going to go all out and get an amp you may as well go all out and get new component speakers. what you can get today will blow away your stock speakers. i would suggest you look into the alpine type-x line. while the newer ones are still great i prefer the older versions. i have a pair of spx-177r component speakers in the doors and the sound is amazing when setup properly. depending on your point of view they can be perceived as expensive, but when looked at in relation to the cost of the car they are very reasonable
Old 11-20-2009, 08:49 PM
muck-raker
kidrock's Avatar
Also using an Alpine amp, channeled to front and back (including tweeters installed in front door panel). I would definitely recommend a high quality amp...you'll need it to hear above the sweet drone of the flat6.
STONE
Old 11-21-2009, 07:22 AM
wannabee wannabee
WIL84911's Avatar
Thanks again nineball & kidrock. Will think about going all out since it makes sense.
Old 11-21-2009, 02:57 PM
dshepp806's Avatar
MBs are good....
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 11-21-2009, 05:06 PM
