Wer bremst verliert
JohnJL's Avatar
Transmission and Supercharger Oil Cooling Design
Looking for help designing a cooling system for the transmission and supercharger. Although the manufacturer doesnt mandate a cooler, the supercharger runs super-hot. The last one failed and I'm still in dispute with the manufacturer over the cause but they arent claiming heat.
The transmission is a pricy bit of kit, a built, shortened G50 with a Guard LSD.
Both components support the car putting out around 400hp at the wheels. I already have a transmission temp gauge on the dash.
I've never designed or installed one of these so I'd appreciate some pointers. I was planning on the following additional details;
-8 lines
ECU to turn on the pump as soon as the car is running (since in this design the Transmission acts as the sump and the supercharger will be nearly empty when cold, though I could choose a mid-point drain location to mitigate this)
Sightglass on the supercharger to verify oil level
Suggestions?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-28-2009, 04:37 AM
DUK DUK is offline
DUK's Avatar
Just my opinion... Do you really want to use gear lube in the supercharger? Also I would put the filter in between the trans and the pump. And maybe one where you have it between the supercharger and the trans. And now that I say that, do you really want hot oil coming from the supercharger going to your high dollar g50?
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 11-28-2009, 05:46 AM
Wer bremst verliert
JohnJL's Avatar
Thanks, and good questions. My initial thoughts were that since the transmission is the lowest component, its easiest/best for the pump for it to be the "start" of the system. The flowrate of 1-2 gallons per minute should provide enough throughput that the supercharger won't "superheat" the oil anymore. Also, the supercharger isnt sensitive to oil temps whereas the transmission is.
As far as the lube, the supercharger gear assembly is just a set of straight-cut gears engineered (the manufacturer says) to live on self-contained engine oil. I'd think a cooler, filtered and continuously-circulating supply of oil (redline) designed for gears would be best.
Happy to hear if I'm off or alternative flow designs. THanks!
Old 11-28-2009, 06:12 AM
Wer bremst verliert
JohnJL's Avatar
Is this what you mean?
Old 11-28-2009, 06:23 AM
DUK DUK is offline
DUK's Avatar
2000 & 2007 Dobies
Old 11-28-2009, 06:32 AM
Almost Banned Once
sc_rufctr's Avatar
John
I like the unique approach and it would work but why re invent the wheel?
Why not use a traditional set-up with a dedicated cooler for the supercharger using engine oil as the lubricant?
I think the gearbox oil may be too thick for the super charger gears at high RPM.
What weight oil does the manufacturer recommend for the super charger?
- Peter
Old 11-28-2009, 06:39 AM
Crotchety Old Bastard
RarlyL8's Avatar
I also think that the engine is a better source of oil for the supercharger. Much more cooling capacity and proper grade oil. The tranny is best left alone as it will be working harder than stock to support 400whp which creates more heat as well. Any track use would heat up the tranny fast trying to cool itself and a supercharger.
Old 11-28-2009, 06:52 AM
Wer bremst verliert
JohnJL's Avatar
John
Hi Peter,
I was looking to incorporate the supercharger into the tranny cooling because I am planning on installing a cooling system for the transmission anyway and it would be opportune time.
The manufacturer says the supercharger is fine with its self-contained oil supply, but they also endorse (and Corky Bell advocated) adding a separate supply.
Autorotor recomend a thick grade of engine oil, though they aren't specific.
Old 11-28-2009, 11:58 PM
Wer bremst verliert
JohnJL's Avatar
Thanks Brian. I have not done any calculations but I would think the supercharger and transmission would be fine from a temp standpoint? There are 2 litres of additional coolant, and a derale cooler with a dedicated fan. If the supercharger is supposed to be fine with no external cooling and the transmission is not overheating, then they would be OK?
Old 11-29-2009, 12:01 AM
Almost Banned Once
sc_rufctr's Avatar
Originally Posted by JohnJL View Post
... If the supercharger is supposed to be fine with no external cooling and the transmission is not overheating, then they would be OK?
Your logic is sound...
As I said I like your unique approach.
I'm interested to see how this works out.
- Peter
Old 11-29-2009, 12:38 AM
